Help! Left Keys In The Boot! -.-
Frameless windows are relatively easy to pry the window away from the door to get something down there to unlock the door from the inside. At least it looked that way when I had my keys locked in the car. ^_^
take out the back of the rear seat and unbolt the plate which is behind it.
this should get you to your keys
thats if your doors arnt locked and the boot release doesn't work (which is the problem i had) :D
Edited by beRwick_GTRage
haha well... doors are locked, boot release wont work and as for sticking something through the window seal, yes stuff fits but i cant seem to find a hard enough stick to push the door lock open so I've given up for the day! :D
coat hanger always works well :P
ok so how on earth do the back seats get removed! i been trying for like half an hour but nothing moves!!! :D:P
Top half, UP
bottom half, the front has to come UP, then once the two pins are free, the whole seat comes FORWARD+UP
I had the guys at Chaddy car wash lock the keys in the ignition... ...The only thing I can think of is they hit the car with a really strong spray of water and it locked itself down... ...I've never ever had it happen to me... ...I'm just glad that it also shut the engine off... ...Screwed up their work for about an hour while I got the second set from my parents...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
