Hi there, I've had my RB30DET for a few months now, it's been running off an RB25DET ECU with a Mines chip (as far as I know) and seems to run 'okay'. Well apparently the RB25DET ECU is hard/expensive/not worth chipping for tuning. My mate gave me a working RB20DET ECU but problem is, my RB30DET has had VCT retained. Any recommendations on a controller to use to activate the VCT solenoid? (I assume it's as simple as that? I don't know much about it)
I was looking at something like this: http://www.jegs.com/i/MSD-Ignition/121/896...roductId=754062 - anyone used one of these or something like it before with success?
Cheers.
https://www.sau.com.au/forums/topic/301396-vct-controller/
I used that same Msd unit when i couldnt get the Nvcs to activate when i changed from auto to manual..... Worked good, no issues although i think the gain was verrry minimal when playing with different settings on the road.
Boost did seem to come on slightly earlier and a little faster but as i said there was very little difference almost undetectable between on and off....
Bear in mind i was using the stock ecu, but i think the benefits of the nvcs can be compensated for or over ridden with a good tune of ign timing down in that area
https://www.sau.com.au/forums/topic/301396-vct-controller/#findComment-5004708
being in NZ why not just get a link G4 plugin and save yourself the hassle?
Unfortunately I'm not made of money, I'm probably going to use a NISTune daughterboard, I'm not really keen to spend $2k+tuning on a standalone ECU when I have a fairly basic engine. I wouldn't think hooking up a bunch of extra wires would be $2k+ worth of hassle.
Ah sweet that someone has used it in the same way, I found a few forum posts about others using it on the same engines too so that's good. The engine has already been built with VCT retained so I may as well get a controller for it.
https://www.sau.com.au/forums/topic/301396-vct-controller/#findComment-5004800
Get the controller. You can find the optimum on/off positions on the dyno. As per one of SK's posts i read years ago: do one run with it on and one run with it off - the charts will show you where to set the changeover points.
https://www.sau.com.au/forums/topic/301396-vct-controller/#findComment-5005967
the msd switching system works but needs a coil pack adapter, and is dear. I have a spare tach adapter you can have if you decide to go that way though. (i use alot of the switches and adapters for NOS installs)
the jaycar one works and is about $35 bucks (search in the forced induction forum, i posted part numbers)
or use a Z32 ecu like bubba posted.
https://www.sau.com.au/forums/topic/301396-vct-controller/#findComment-5009249
No coil pack adapter needed.... just take a signal for the tach output from the ecu. Worked fine for me.
https://www.sau.com.au/forums/topic/301396-vct-controller/#findComment-5010623
Yeah I think the tach adapter is for the non-digital MSD RPM switch?
Also, URAS, I couldn't find the part numbers you posted from jaycar but I found this http://www.jaycar.com.au/productView.asp?I...mp;SUBCATID=347 - but how can you use that to make it switch off again at higher RPM?
And I could mod a Z32 ECU but I already have an RB20DET ECU that I got for free and the Z32 one would cost more than a VCT controller along with having to modify the Z32 ECU/my loom which I'd rather not.
https://www.sau.com.au/forums/topic/301396-vct-controller/#findComment-5011766
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
