Should I Amp My Speakers? Full Alpine System.
By BASHERnissan · Posted
Cheers thanks for the help mate I’ll see how we go with that one -
Sounds like you've started from the wrong base map. That image I posted above is from the base map for the RB25DET (this one, Pro_R32R33-113_RB25_VE.hr32r33-113). Maybe load that base map and import the data from your current tune if its otherwise good. -
https://apnews.com/article/japan-nissan-honda-evs-foxconn-782913451d6487ed177a3517a9ba5be5 The world's worst kept secret? What are we to expect here?
It is plug and play, load up the base map and off you go. Throw the stock MAF(s) into the bin and run an intake manifold vacuum/boost reference to the ECU. Preferably to run it to an external MAP sensor. Get a Haltech CANbus wideband. -
Yep not a problem I’ll take a photo once I’m home
