  • Replies 230
JMW = fail
Luke ENR34 = fail
Pepsinator post 26 = fail post 38 = baller
Joeyjoejoe etc... = baller
PeterT = baller
red screamer = epic fail
Nismoboy = baller
I'm glad im not the only one that think half these cars have shithouse offsets. 10 degrees of negative camber, a 215 stretched tire on a 11" rim with the entire wheel tucked under flared gaurds that scrub and spin the whole way through second gear with 140rwkw because there is 2cm of tire touching the road just really doesn't do it for me. I agree some look tuff to look at parked up, but to actually drive them around in a performance car i don't understand the point.
Funnily enough its the same people that you hear about saying they can't get traction through three gears on stock power outputs.
Edited by PM-R33
hence why drifters stretch tires.
to do what your talking about a wide body would be the way to go have something big with proper tire fitment sitting flush.
Edited by 32_Dave
There is no point. I for one am not that ignorant to think it’s a constructive “mod”. It serves no purpose other than aesthetic.
The ride is far worse, the tire wear is obviously far worse; you cannot turn anymore than half lock, and if you make any attempt to corner hard the rims more often than not grab the guards.
Personally, I think a car looks ridiculous with “sunken” rims, it looks tacky with the gap often left.
These “drifters” are just copying the Euro guy’s from the early 90’s and late 80's :blink:
Viva the early VW/Porsche/BMW "tuners" :P
Oh no doubt, however you can get a good offset matched with some proper tyres that sit nicely. I don't mind the tyres sticking out of the gaurds slightly, i like that look. However half the rim sticking out with stretched tyres tucked underneath with ridiculous camber just isn't my thing. Thats the joys of doing what we do though, every car is different and every one has different tastes.
Edited by PM-R33
its hard to find a balance, but it is possible...
i sit my rims about 15mm out of the guards, and then stretch and roll to fit... however i also have the tyres set up 100% for performance first, i.e. near flat camber on the rears, and a tiny bit more on the front, i also run a lil +ve castor. cant remember the exact figures as i did it 2 years ago and am so happy with it that i haven't had to change it
with 300rwkw i couldn't possibly have a setup that killed the traction just for looks.
With the exception of a car dragging its sideskirts on the ground I doubt there is anything that would catch the eye of a copper faster than some of the above posted ridiculous setups.
As for aestheitics I can see where you're coming from Josh. Its some kind of competition to see who can have the ugliest setup isnt it. :P
Far out Trent, back in port G days. Remember the days back when D1 garage was down the rd from my work and i could hear u guys come sliding onto mooringe then into the shop lol. Until Vahoumos (sp) wiped out a power generator to half the block :banana:
hahaha its all alleged :cheers:
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
