hey i have tryed to sell this a couple of times at diffrent stage's of the build now new house almost finished really need the cash now but if i dont sell wont be the end of the world but will be for sale antil completion of my house.
nissan cefiro a31 1988 came out rb20de an auto as they all did engineered for all mods
colour-white
kms-124xxx
trans-manual rb25 box
rego rwc- n/a
mods-
forged bottom end rb25(just had run in tune on tuesday)
adjustable cam gear
nismo 555cc injectors
bosch 044 fuel pump (not installed but brand new)
garret 25/40 turbo
z32 afm
cusco os clutch an cermic fly wheel
dump pipe
r33 brake upgrade and 5 stud convo
coilover fully adjustable front an rear
fmic
hks oil cooler 12 row i think
uras body kit
come with light wieght racing rims(not installed need new tyre's)
r33 stockies painted black fitted
defi infomation computer with heads up display
k series gauge's oil temp,oil pressure,water temp
defi boost gauge
mircotech lt10 gettin a hand controller next week
hks boost controller
hks turbo timer
bride bucket seat and racing harness
after market steering wheel
blitz bov
thats all i can think off at this time
price-11000 firm (motor cost 4.5k alone) no swap's excepts for gt forrester or stagea
contact- 0437958298 or pm
location- colac vic 3250
will be for sale till mid feb
https://www.sau.com.au/forums/topic/301436-nissan-cefiro/
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
