  • Replies 63
Posted Images
I cant speak for anyone else, but I'm hoping to do an sa to nsw roadtrip and back via vic next year during winter
most of that time is on mt hotham tho, so i dunno how many people would actually be keen - my plan would involve a drive back via the great ocean road
-D
Shoulds promising!! Hope it happens..But should come see some racing if you have the time
Jess ill be over in October need to call you about that :);)
Oh awesome!! Yep give me a ring :ermm:
Whats on around July/Aug ? Not quite sure when I'll hit up the snow - as it is the GTR is pissing me off with niggling issues so I have to make sure I got a reliable car and that I can afford to go - if I have a major problem its goodbye holiday hello rebuild heh
but I'm keen. Ive not been above Albury since I was uh 2 yrs old...
-D
I will be helping run a supersprint at EC on the 11th July. If you have a CAMS licence more than welcome to enter..There is FOSC on at Wakie on 7 & 8th August which is a huge race meetings with lots of different cars that I will be more than likely working at..A Supersprint is on at Wakie on the 15th August as well
Other than that there will be trackdays on aswell in those months
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
