hey guys,
got my car back from gtech performance on thurseday, car is tuned on e85 fuel running a vipec ecu the car made 317.1 rwkw
they did get it to 328rwkw but wasnt very safe as there was a missfire anything over that and also injectors are at 85%.
good this is when u pop the bonnet you can hardly tell anything is done to it, apart from the big ass 50mm pro gate :D
car is not complete yet but safe to drive on this power level, will be going back there in February when they open up agian for bigger injectors, different ignition setup and another tune
lets see how she goes.
i will be putting standard supsension in the car soon enough, a set of slicks and taking it down the strip for some 1/4mile action.
heres a pik from there christmas party the other day, and also have just a sample video of the car (nothing major just a bit of up and down the street screaming)
ps. the r33 rims are only on the back as the 18s had wires hanging out and wasnt suitable for the dyno.
Edited by WARLORD BAS
  • Replies 43
for the fuel setup i have 2 x bosch 044 fuel pumps, surge tank, 800cc injectors (or there abouts), surge tank, braided fuel lines in the boot, new fuel lines from boot to fuel rail, new fuel rail, vipec ecu, garrett gt3540, catch can setup,
and thats the basis really
e85 is only available at the hoppers crossing petrol station on old geelong road, pump number 10.
car is all over the road, but i cant even drive it really as i dont get my license back until 05/05
Ah nice work, I am thinking of upgrading to a surge tank, and considering replacing lines while im there, and mayb try e85 on a new tune. Do you need special ethanol injectors or pumps for e85? Or just a higher flowing system?
in regards to whether you need special injectors, im not sure, but as u can see i have 2 bosch 044 fuel pumps which u can get most places.
the thing to remember though is that e85 burn ALOT quicker.
not sure exactly, as i got it done as a packege mate.
nytsky - i know that e85 needs a much higher cc injector and there dyno is quiet a low reading dyno, but as i said its not complete 100% so everything will be sorted out in 6 weeks,
and as they say, a dyno should only be a tuning tool so im hanging to take out to calder/heathcote and see what mph/et i can get.
feels absolutely mental :D, couldnt be happier.
GT35 only made 320rwkw on E85? How much boost is being used?
I ask because you can virtually do that on PULP, with a 3076!
Regardless of the fact it is a low reading dyno - cause lets face it - every 2nd post says the dyno they used reads low these days.
Indeed take it to the track, i would imagine the MPH will match 320rwkw. However it should be 400++
you definately dont need to upgrade lines.
Seen plenty of cars make 450rwkw+ on factory Nissan lines. More about the fuel pump being decent :D
r31 nismoid, as i said, its having missfire issues and the tuning is not finished, also as i said dyno dont mean anything, its about the mph thats what im waiting for
the turbo is a gt3540 with the .64 rear and on 18psi boost
i run 323 rwkw on e85 on virtually the same boost and a smaller turbo...
as for fuel, 2 x 044's and a surge tank are not req'd (nice to have tho)
i run nismo 555 injectors, a nismo drop in fuel pump and stock fpr, lines, rail etc
What did the Vipec ECU set you back?
Vi-PEC plug-in ecu is $1881 inc GST
As a side note...
we put some new Injector Dynamics 1000cc jobbies in a completely standard car the other day...the Vi-PEC controlled them beautifully. At idle the AFR's didn't jump around at all, i reckon we could have put 2000cc ID injectors in and it would have been just as good. These new injectors we are getting out of the States are the latest technology and when driven by the Vi-PEC are very impressive indeed.
Edited by DiRTgarage
You might want to think about reading the post again, Bas stated the car IS NOT COMPLETE, 317kw is the current tune as they had injector issues, as for 400++ wow, stock bottom end, no worries :)
Did you read? There were no injector issues at all. 85% duty is not a worry... read on and you shall see why...
Now further detail is provided... a GT35 in .63 is pretty much at the limit @ 330rwkw miss firing aside. You'll also probably find the miss firing could also be induced by .63 rear.
It is horribly restrictive for that compressor.
There should not be issues with fuel because of the following...
1. 800cc/E85 is more than enough for 370rwkw+
2. Two Bosch 044's with E85 will support 400rwkw+
Given the above... You'll never reach those limits with a GT35/.63, so all is well and good. Leaves one issue. Miss firing.
Would likely be coil packs and/or plug choice, but i wouldn't be surprised as i said above, if it was indeed the rear housing choice playing a factor.
ALL ISSUES ASIDE, here is a little clip of what the car sounds like.
as i said, im extremelly happy with how it has turned out and cannot wait till its finished, so we will see what happens once i take it to calder.
Thats intersesting i would have thought that turbo be good for 380+ on E85 considering my little HKS 3037 .68 has seen 350 on numerous dyno's.
What mods are used to make this power? Have you done anything special to be able to run e85?
And where abouts do you you get e85 in melb from? Last I hered there were only 2 servos selling it.
The other servo that has e85 is fueltown(heading towards the city) next to southland on nepean hwy. Look for the big banner cant miss it.
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
