^^^ What he said.
Mine did (more due to unsecured speaker) and it dead shorted the battery. I had just come to a stop on a 100km/h highway at a red light. In the Right lane... with no hazards.. no tail lights... no brake lights... at 10.30pm.. :) Very scary.
Edited by gotRICE?
yer i was looking for a set up that didn't need a sub, still want a decent amount of bass tho, just not sure if i really want a sub. whats the best way around the bass with out a sub?
get some good 6x9s in the rear, components in the front and a 4 channel amp.
Problem solved.
I'm not really keen on subs for skylines, plus i don't want the added weight.
ill be getting a new headunit and some 6x9s for my 33 soon too so get some pics once you've done it as im keen to see how it goes.
I have alpine type S all round 6.5" coaxial in the front and 6x9 in the back run off a 4 channel which sits hidden under the passenger seat ( i like my limited boot space). Had to cut bigger holes in the parcel shelf and mount them on spacers to clear the battery. Finished off the doors with dynamat and dynamat and dynaliner under the rear seats. Sounds awesome for entry level speakers, great well rounded sound when amped and no real need for a sub :rofl:
  • 2 months later...
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
