MODS PLEASE KEEP THIS TOPIC.. AND DELETE OLD TOPIC..
NEW PICS, NEW 20S, NEW MOTOR, NEW PRICE
>30K SPENT
PAINT TURNS AQUA FROM BLUE SCOOP IS HARLIQUIN !!! CANT SEE IN PICS!!!!!
2006 gt-b front, 1997 b4 back , 2000 wrx turbo, all widebody from doors, built in 2008
ALL COMPLIED AND PLATED READY FOR REGO
WRX MOTOR AWD TURBO ENGINE LOTS WORK
list too big motor pushing 300hp ATW..!! SEE PICS!! over 30k spent, 3g spent on motor .in the last month (receipts)
INTERNALS
ALL CUSTOM PIPING
BIG INTERCOOLER
NEW GAUGES
NEW BOV
NEW TURBO TIMER
NEW BOOST CONTROLL
FULL WIDEBODY
NEW ALPINE CD WMA MP3
ALL CUSTOM BLACK LEATHER INTERIOR
doors leather
roof velvet
5 SPEED
20s CHROME
bigger ihi TURBO
FULL DYNO TUNE apc
TWIN SPORTS EXHAUST TO 2 CANNONS
apexi pod
wicked wrx grumble
PEARL PAINT BLUE TO AQUA
HARLIQUIN SCOOP
$16,000 ONO.
18G SWAPS. S15, RX7, GTR, 350Z, S2000, EURO.. 0430828859
Edited by katurbo
And that's was just the photos imagine if u seen it in real life... You'd probably go crazy or something... espesially if it just turnd aqua green in front of you... Man I don't even wanna think about it's just insane...
    • Hi Lads Anyone have or know where i can find the wiring diagram for the dash cluster of a 2003 V35 Skyline? The G35 one is not the same as the V35 Thank you!
    • Ok will do, I think I originally had 1 bolt off for the sway bar on when I took off the strut but will give this a ago. Thanks Duncan! My sway bar has play also when I move it around, hoping that's the source of my squeaking because I can't find anything wrong elsewhere
    • odd. I thought all the top race teams used them.
    • undo the sway bar link, put it on last. put a jack under the outer ball joint on the lower control arm to raise the hub and off you go
    • I don't know how this is even possible. I removed the strut to do some work (it came out fine, and keeping in mind that I didn't put things back in the same order, but did this on purpose because I was supposed to remove the strut originally instead I tried to remove other shit first which made things a head ache) but now the problem is that it won't go back in. The alignment between where the bolt hole for the strut is and the j arm where the strut slides onto is way off, about a 10cm difference or more. In order to make it fit I'd somehow need to push it up. I tried to compress it with a spring compressor and install it but the compressor was getting in the way and there was no working room. On the photo you can see the difference between the shock and the thread that it's supposed to go on. The only things I removed in total were - the top bolts for the j arm but I didn't remove the actual j arm - the 3 bolts that hold the plate for the brake lines - the sway bar link (this bolted on back fine) - the strut/shock absorber
