i have for 96 r33 gtst, s2
Bonnet $150
Right Guard $70
Right Headlight $60
Rigt Door with trim $70
Boot with Spoliler $80
Rear Bar $70
Rear Lights $60 pair
Front Winshield $100
Rear Winshield $100
Rear Left Quarter window $60
Rear Right Quarter Window $60
S2 Steering Wheel, (airbag) $150
Climate Control unit $100
Front Seats, No tears. $150
Rear Seats, No tears $70
Dash Board, (airbags) good condition $200
Centre Consol $50
Roof Lining $70
Rear Right Top Quarter Trim $40
Rear Right Bottom Quarter Trim $35
Rear Left Top Quarter Trim $40
Rear Left Bottom Quarter Trim $35
Floor Carpet, good condition $80
5 Stud Conversion
Front'' right and left
Brake Calipers (sprayed red)
Brake Pads (good condition)
Rotors
Subframe
Suspension Components/no coilovers
Brake Line
5 Stud Hubs
Everything Exept coilovers
All in one piece
All bolts Included
''REAR'' right and left
Rotors
Brake Line
Handbrake Cable
5 Stud Hubs
Diff Shafts
Suspension Components/ no coilovers
Everything Exept Coilovers
All in one piece
All bolts included
$1200ono
any other parts you need, ask i will have
If you need pics, ask i will post
Western Suburbs, Melbourne
Edited by boz_soljah
https://www.sau.com.au/forums/topic/301476-wrecking-r33-gtst-s2/
  • Replies 102
UPDATE !!!!
Wiper Washer Bottle $20
Radiator Overflow Bottle $20
Radiator, Fan cover, Support $100
Ac fan $20
Ac Radiator $50
Bonnet Release Cable Setup $30
Centre Dash Piece $50
Cluster Surrounding $50
Centre Console $50
Bottom Dash Steering Cover $20
Right Console Cover $10
Steering wheel cover $10
Side computer cover $10
Glove box with pins $20
Glove box, Behind part $20
hey mate, can you please PM me a close up shot of the right side tail light assembly?
if it's in good nick i'll certainly take it off your hands :)
cheers
pm sent
Hi there I'm after a aircon condenser... Do u have one for sale??? Think it's the ac radiator u have fir sale but not sure??? Can u please let me know what condition it's in and where ur located please??? Thanks heaps!!!!
If anyone has an a/c condensor for sale please let me know thanks heaps!!!
yes i do have it, pm sent
Hey mate, have you got the large heat insulated line that goes from the aircon into the firewall and normally silver in good condition?
pm sent
Do you have the plastic inner guard for the right hand pasenger side?
Also the right hand mirror assembly? My retractible mirror motor is broken.
pm sent
gday, how much for the front calipers and where are you located?
cheers
hay, im selling the complete 5stud conversion for $1000, front and rear with all parts, all suspension components, the whole lot, if you want just the front i can give it for $500, complete with all bolts, hubs, calipers, brake line, suspension components, look in pics, let me no
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
