See below -
RE top mounted catch can
Are these used in place of the normal catch can?
Are they any good?
Any one use them?
JJR AUTECH TYPE OIL CATCH TANK - STANDARD FEATURES
- High grade alloy construction
- Light weight design
- Simple installation
- Race quality
- Proven in Japanese street and circuit applications
- 12 Month Warranty
JJR AUTECH TYPE OIL CATCH TANK - INSTALLED ON AN RB26
https://www.sau.com.au/forums/topic/301485-oil-catch-can-rb26/
Nope they are crap. Better off getting one made by LF Performance and fit Mines baffles in the cam covers.
Do it once and do it properly.
Well, I would argue with that. The Autech arrangement is similar to the Nismo oil separator in operation, but its placement gives better head for return flow to the sump. There are other arguments for the arrangement, which was praised in an article in HPI magazine a couple of years ago, but I don't recall the details.
I was convinced of the argument by Danny Fisher, at Imports 101, who understands all of the details. I bought one from Danny and he set it up for me in a two stage arrangement with a "standard" catch can, that I already had fitted - both of which drain back to the sump.
If you want to understand oil flow around the RB26 engine, talk to Danny.
The Mines baffles are good, but fitting a head drain is better.
Cheers. :D
Thanks - I will give Danny a call to discuss. I was hoping to run the top catch can only?
I was under the impression that it was a alternative to the normal storage type catch can?
I am trying to achieve the best solution against oil surge etc without having to dismantle or remove the engine. At this stage I am looking at keeping 1lt overfill in the sump, having a good breather/catch can arrangement, baffles in cam cover/head drain, oil cooler, and keeping the revs under 7500 when doing a bit of circuit work.
Cheers.
:P
I think baffles are a must and easy to do with the engine in place. The head drain is debatable and there is a massive discussion on the merits of this in the FI section.
I'm a bit sceptical about the merits of that design of catch can as it will only drain back when the engine is not under load. When you are out on the track, if you have engine that breathes a bit, then it's going to get full pretty quickly and pump a load of oil into your intake.
But if Canute has seen a better solution using another catch can along with the JJR one then it might be an option for you. Having two catch cans in the engine bay would give me the shits. Maybe Canute can post up a pic of his engine bay so we can see how it looks.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
