Hi!
I have some trouble with my autobox in the stag (S1 RS4 V). When i get above ~140km/h it feels like it start slippering in the box and don't put the power to the ground. The slippering seams to increase with increased speed. It hardly wants to get to the speedlimit at 180.
1st & 2nd is no problem at all and it get all 4 tires ti spin some meters, but something feels wrong in the the higher section of the gearbox. I have tried with and without O/D and no change.
Have anyone had this problem and how do i solve it? (Don't want to disassemble the box if i can avoid it.)
We tried to break a world record and I'm not happy that the car got power left but don't get the speed. "Only" 170km/h with a snowracer behind... :)
(But i like the sound...)
Edited by sirmiro
https://www.sau.com.au/forums/topic/301492-gearbox-problems/
check the level of the fluid it has a dip stick . and it is possible gear box is not warm enough . have heard of them not even going into 4th untill the ehgine ang gearbox is hot enough
and that video is f**kin nuts . we got up to 70 with 3 plastic $3 tobogans on 3 different ropes behind same vehicle once
Edited by lachlanw
you may wanna think about making a cover for the front of the radiator to help the engine getting up to temp
your trans oil passes through the radiator to help keep it at a constant temp and it is possible that its not getting warm enough
i was watching a program (ice road truckers) and they had trucks running in temps a bit colder than yours and some had most of the front grill blocked off to prevent overcooling i presume
yeah because thinking about it the auto trans cooler/warmer is in the bottom(cold) tank of the radiator and at those speeds and temperatures the bottom tank is probabaly cooling the auto oil way cooler than it should be
I thought Turnips were crazy, but Sweedes are f**king awsome. And I've been there.
But yeah! on the tranny "cooler". Initially the radiator is used to warm up the oil to get the gearbox up to temp. If you are towing etc, a cooler is used to keep the temperature getting too high.
Thanx so much. Haven't thought that it can be to cold.
Which temperature is recommended for the transmission? I need to mount a gauge for it just to have control, but it's no idea if i don't know where it shall be.
Temperature is changing between 0 and -20 degrees C. We just need to be crazy so we don't freeze to death. :D
Auto trans fluid need to be a little less than engine temp- say between 80 deg C and 100C. You could consider some sort of radiator blind like trucks have so that you can cover part or all of the radiator core.
Hi Trans temp should be around 100 to 110 Degrees so maybe look at a few thing`s,
look at if you really need a TRAN`S COOLER ??,as it`s going in to rad,look at your Thremostat & what temp it is,mine come with 82 degrees C so you will need to get ENGINE TEMP UP may need to block most of the air flow ,as we did when in UK IN WINTER & TRANS is very temp sensitive ,good luck cheer`s Chuckie,
Thank you again!
You in here saves me over and over again. :D So wonderful to have a place with all the knowledge as in here.
I'll start to mount a tempgauge to be able to check it. :) Then i'll think about changes. I've got the intercooler in front of the oilcooler so i'll guess it rises the temp a degree or two. ;)
Need to get a sensor asap. :D
(And I'll get the enginetemp to the right level in about 2min.)
Edited by sirmiro
Bet you gave the oncoming traffic a fright!
We had to abort because of them, and they started to flash the headlights like they were some kind o polices. Unfortunatly we didn't get the real police on camera. They were very suspicious when they saw us just before attempt one. :banana:
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
