hey guys, im a classic noob.
just curious to know, whats a c210 coupe worth?
been offered one by a close friend and dont really know what to pay for it.
cheers! :)
Edited by GTR-boy
https://www.sau.com.au/forums/topic/301499-c210-coupes-what-are-they-worth/
dont have pics atm, im really after a ball park figure based on condition
kinda like
shit = $
okay = $
good= $
Here's one for $500. http://motamota.r31skylineclub.com/index.php?topic=138224.0
JH
thats for the input guys
i think thats rascov's car, judging by the msn email on the add.
im going to go see the car tomorrow again(if the guys are there) so will try and take some pics
thanks guys.
looks like ill be getting that coupe.
dads mate offered it to me for about 2k
i got he garage space, a welder, panel beater mates and some money and 9 months till my P's
its currently got about 100 or so cars in front of it. so it might take a while
pics, condition, running?
were u on da hunt for a c210 form wreckers recently aswell ?
yeah i rang around to a couple of wreckers.
have no pics of the c210. the seller has decided to keep it, so no more c210 for me :D
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
