As title says. Did anyone get any good presents for their baby, Aka. Stagea for chrismas?
I didn't get anything but I did make a pact with myself befor chrissy that I wouldn't buy anything for the car till after chrissy. So now as a result I have a nice list of toys I'll be getting very soon. Including a FMIC, some gauges, rear strut brace etc.
Edited by mattye
jaycar iebc + hand controller (still waiting for it to arrive) ~ $50 for iebc, $67 for hc, $7 for connector and $7 for postage
alpine type r 6 inch coaxials for the rear doors - $80 from a mate
and maybe a new o2 sensor for it too as i found out that the neo can use the el falcoooon sensor too and i can get one for $66 cos my mate works at supercheap :wub:
real good tidy set of r33 gtr wheels . (realistic) dream wheel . and a 4 x 50 watt rms amp so i can install alpine cda 9887 i got for birthday . car is also getting rust attended to under mirrors , well was going to . had trouble finding the rust . had to check on the here where it was supposed to be . wasnt worth worrying about
i got some cash i wouldnt mind buying Kingcrome socket and spanner set :wub: $100 each from autobarn!
well i got $$ to buy one actually..(strict instructions) :) sounds like i know where i'll be getting it from ^____^
Edited by atomaly
I've bought nothing for my car, but plan on spending a little bit in the new year to get the stereo working more to my liking.
I'll also add cruise control and get the power windows working with the (already installed) alarm too. I should have done the window control straight away when I had the alarm installed... Meh, oh well.
s i said before, caus I got it early, a JJ front facing plenum. Have to wait for my shoulder to heal a bit before I tackle the fit. I hope to do a DIY, and Darrin is going to fit one too, so hopefully a good outcome will eventuate.
So are you going to get a fmic as well Hugh (or do you have one already)? I got my cooling pro stealth fmic before I thought I would be getting an RB30 so later in the year I will be getting a foward facing plenum as well as changing the fmic ($$$$).
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
