Hi guys
I just put the engine back in my R33 with a T04e (brand new) (bought it off someone who didnt want it anymore but looks like it is probably a cheapy), now i have cranked up the engine, it all runs fine but i give it a few revs (4000rpm) starts blowing smoke while reving and then at idle after that until it settles down again. Im pretty sure my turbo requires a restrictor, now i have left the stock bolt in the block which has a restrictor in it i believe, but i believe i also need one on the turbo side as well? am i correct? now with the line im running at the momment looks like it has a 2mm-2.5mm fitting (turbo side) is this too big? or is my problem not turbo oil related? cheers
https://www.sau.com.au/forums/topic/301545-t04e-oil-restrictor-size/
the drain isnt kinked or blocked, but once i placed the restrictor in today the smoke has settled heaps, should i take it back out and see if it smokes again? i have read from other forums that i should use a restrictor as the pressure pushes past the seals on a T04e but sounds to me they could be wrong, i did not use silicon on the drain only a gasket. What is everyones suggestions? rip the restrictor back out?
Should never restrict oil to a sleeve bearing T04E turbo. specially if its oil cooled. Without oil pressure and flow the bearings worns out in a lot faster rate. Smoking with no shaft play means the bearing housing is flooded with oil. Find out why it can't drain oil is the key to fix this problem. Unless the CHRA of the turbo is very poorly built.
using the stock drain pipe although the hose is a little monged (not fully kinked), could be flowing alot better, is the stock drain suffient? im guessing it would be the drain, just cant seem to find a good hose that will fit perfectly.
your factory turbo drain?
no good, factory turbo flows less oil - you need a larger line, this will be causing pressure blowing oil past the seals.
My oil drain for my T04E i could easily stick my index finger in down to my first knuckle so it was what... 2.5cm diameter or so?
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
