Hey people this is my first 31, picked it up mid 09 and its in a bit of a sad state not sure if any of you know the car and could tell me more bout it, I swapped it for my Hi-lux with a lad in ballina. before i got it, it sat on 18's had gauges across the dash with wrx bucket seats installed.
Current specs are:-
* Silver top RB20DET (engineered)
* 5sp (not sure what its off)
* Microtech LT-10S, running out of the box tune needs full cold start tune, Runs alright once warmed up
* 3" Exhaust off the dump pipe (bigger cat I think)
* Silo front seats
* Import dash/cluster & centre console (temp & fuel don't work properly, speedo out 10 -15k's)
* Boost Tap
* Stock turbo currently fitting a rb25 turbo
* SMIC
* Cheap lookin Turbo timer
* Standard diff :eek4:
money is a bit of an issue atm (hence in long term project forum) so my first priority is to get it back on the road should be achievable by start of Feb.
The old owner had the boost set too high and I had no boost gauge so it threw the wheel off the exhaust side of the standard turbo (god knows where it went lol (see pic)) recently purchased an RB25 turbo just chasing the coolant lines/bolts because the bolts in the RB20 turbo were the wrong size.
currently getting the tail shaft rebuilt will be in this week sometime, the centre bearing was flogged out and the drive line place wouldn't just replace just the centre bearing they wanted to fully rebuild & balance it so I just got it done.
She has a bit of rust that is in need of repair for rego (see pics) hoping to eventually get a cleaner S3 wagon as a project base before I go too far with it but need to get this on the road first. have lined up a pair of guards just need some paint and cut a bit out of the tail gate and behind both guards, fit a pair of tyres also have some slotted rotors coming.
have bought a boost gauge just got to fit it
I'm doing all the work myself don't know anyone that knows much about what I'm doing so I'm on my own, so if anyone can give me any pointers would be much appreciated
Tail Gate
Drivers Guard
Old Turbo
SMIC
Turbo Off
Passenger side behind guard
Drivers side behind guard
Front end off
Waiting for tail shaft
Dirty Under body, will paint and clean if I get time
found a doner car last night, put a deposit down this morning, going to pick it up tomorrow morn, bus leaves 3.20AM :-o so looks like i'm going down that route.. cant wait for the fun to begin
Hey man nice projected. I wouldn't mind doing a wagon projected with my spears out of my sedan as a daily driver.
The rust under the front guards is normal and a flamin mongrel to get ride off.
You gonna put all your good stuff in the new one or use the parts off the new one on this one?
got all the way to brissi, 9hr bus trip got there to look at it and it was the biggest piece of shit I'd ever seen..
he was some old prick wouldn't even leave the comfort of his air-con office, send someone else out side was one of the dodgeyest pricks around I'd say, was hoping to get it to put all my shit out of my car into it was supposed to have 180,000 on it.. had oil all over motor shot rocker cover & exhaust gasket, smashed pass side wagon glass stuffed seat belts no high beam or tail lights dirty interior, pass mirror hanging on by the just the adjuster oil nearly at a drip from the diff, rust when told no rust paint severely faded scratched.. didn't look nothing like the pictures you'd swear it was a different car
i know couldn't expect much for $600 but i worked at a wreckers and we bought better cars for $50, he wouldn't even go under $500, he told me it would be fine to drive back 5hrs to Coffs, it wouldn't have made the border and if it did nsw police would have got me and probably made me tow it
caught an 8hr bus home wasted 24hrs of my life and $200
now considering stripping it and parting it out on ebay... soo over it
Edited by de Powa
Cheer up champ.
Wagons are awsome! Find a good shell, paint it black, throw some tough rims on, chuck all the good stuff in it and have some fun.
Insipration:
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
