hey all, im trying to find the best spraying injector around the 6-700cc/min range?
must be a single cone.
high or low impedance
siemans deka? rochester? bosch ev14 ???
any first hand experiance?
cheeres.
Injector Dynamics...they certainly have me impressed. They make a 750cc item that would suit you nicely...we recently put some 1000's in a stock GTR and the fuel delivery was spot on...afr's were rock solid at idle even with varying inlet temps.
have a good read of their website Dave and let us know what you think.
www.injectordynamics.com
Edited by DiRTgarage
I don't know exactly know what ID do to them but from what I read they are a late model higher plessure injector intended for returnless EFI systems .
The moving part inside the injector is much smaller and lighter than older types so easier to control at small and large pulse widths .
ID are supposed to got to a lot of trouble to match sets to ensure uniformity .
Google Injector Dynamic and search here under EV14 Injectors .
Cheers A .
are these the high impedance 1000cc ? would they work with a rb25 power fc without a resistor? what psi are they rated at 1000cc
edit found this chart
cool. but when i can get brand new deka 4's for 40usd each its hard not to take notice. not a fan of "customised" injectors. i just dont know if there is better. spray pattern wise.
ps. does anyone know where i can find technical product sheets for these said deka 4 injectors? (60lb/hr) long series.
there not as such "customised" more matched so you shouldn't have to trim individual cylinders more that a couple of % there also batched so if you have an injector fail you can order another injector of the same batch
also they have a youtube vid of running id2000's in a NA integra there said to idle well
the twin turbo V8 boy are using them too as you can run big pressure to the injectors the 2000cc can run to 3710cc with 130psi to them
i believe they match them by the duty cycles
7000revs 80%
60%
40%
20%
6000revs 80%
60%
40%
and so on
and different voltages
exacly. im running a 12 injector setup. (2 per port shooting at each valve) rather than bashing anywhere all over the port wall.(ie stock)
havent decided whether to have them staged or running in parralell.
i got the idea from nissans new system
also some sucessful race engines ie: s2 quattro pikes peak
funny. still used in the pre diesel r8 lemans cars... meaning the inlet manifold design and 2 injectors per port.. (before fsi injection)
most of the f1 turbos and most of the current wrc inline 4 rally cars. cosworth,scoda etc etc.
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
