hey guys. today I ended up replacing the stock dump pipe with a 3inch stainless steel pipe. While I was in the process of removing the old pipe I accidentally snapped two of the 13mm bolts on the back of the turbo :D Thankfully It was the top two bolts so I should be able to squeeze my little pistol drill in there without removing the turbo. I was just wondering what size drill bit I'd be best off using to drill the snapped bolts out.
https://www.sau.com.au/forums/topic/301589-replaced-stock-dump-pipe/
Ended up buying some screw extractors. I don't know if that's what an 'easy-out' is but they didn't work at all. I ended up snapping one but luckily managed to get it out of the hole i'd drilled. After getting fed up with trying to get the 2 snapped bolts out i made a few calls and ended up taking the turbo to Edsway Engineering over at coopers plains. I can't speak highly enough of the guy that works there. Not only was he on holidays and came in just for me but it only cost me $20 to extract the 2 bolts out and re-thread the holes. The addy is 20/248 musgrave rd, coopers plains for anyone interested. And is it just me or is it friggin hard to bolt the oil and coolant lines back to the turbo? I must of spent at least an hour trying to line everything up.
That totally blows
Thats pretty good for a business to do that.
I have "Rigid" brand screw extractors, never found a snapped bolt they couldn't remove, cost me a fortune for the set but they are worth it in the end of the day.
Best way to solve the problems with those oil lines? braided lines!
Yep the oil and water lines can be a bitch to put back on, hopefully you put thte copper washes back in to otherwise they will end up leaking if they already havent.Next time get some freeze spray in a can (and put it on first before you even undo any of the nuts) similar to inox/wd40 it freezes the bolt or stud so shrinking it slightly and to 'crack' (Not literally) the join, then it gets down into the thread to then act a a lube, its good guys only about $15 a can from auto places.
Hey I've just started up my car since putting the turbo back on and the new dump pipe and there seems to be a bit of steam/smoke coming from the turbo area. i got a new gasket for the turbo flange to dump pipe and just reused the gasket from the turbo to exhaust manifold as it seemed in good condition. I reconnected all the oil and water lines properly so im wondering where this smoke could be coming from? Im afraid to start it up again now
