when i go to accelerate from either a standing start or between gears the car hesitates, goes lean and kind of sputters a bit then goes back to normal. if i accelerate SLOWLY it doesnt do it, and when i accelerate HARD it doesnt do it, im not sure what it is. i tried checking for leaks in the vac/cooler system with no luck.
i took a vid to see if it would help identify the problem. the gauge on the left is the wideband and you can see the pressure/vac/accelerator position on the gauge on the right.. turn up your volume so you can hear what the car is doing.
http://www.youtube.com/watch?v=xPHSLI50Kd4
cheers guys
Edited by SECURITY
https://www.sau.com.au/forums/topic/301603-almost-stalling-on-acceleration/
well unless he has wired the wideband backwards or some crap, it's definately going lean...
It is a tough one! Maybe there's a small block in one of the injectors? Or the pump isn't getting enough voltage or something? Other then that... I was thinking a stuck throttle body but that wouldn't lean it out...
sorry, shouldve given a run down on the car
its got a vipec ecu, it does it under any load, i tried changing the tune around (the vipec has a 1-100 range) i went from 42 in the cells up to 60 and it didnt change much, im pretty sure its a mechanical issue.
My mistake...I didnt see the AFR ratio thing on the left...Definately sounds like some kind of fuel issue. Highly doubt its ignition ( although I could be wrong )....Has anything been done to the car recently ..like prior to this problem occuring ?...Maybe a vacuum line got knocked loose
Edited by GTR-32U
Not sure about the vipec ecu but I had a similar problem on my VH41de safari running a link ecu, it turned out to be an acceleration enrichment issue.
i think you might be on to something, ill have a play around with the accel enrichment tables and see where it gets me.
cheers guys
accel pump adjustment
this car has not been tuned yet has it?
not properly, i had it on a dyno after the engine was rebuilt by the engine builder but the new injectors and plenum havent been tuned in properly. i got it running pretty well using the auto tune and the m5, but this problem just started randomly though.
the accel enrichment didnt work. it didnt change at all. i think its something mechanical rather than the tune.
