R32Gtst
Late 1993
180.xxxKs
Manual
All power options inc. sunroof
serviced every 5000ks
Rego till June i believe
turbo
this is the deal atm!
$9000 with everything
$8500 with Kakimoto catback removed and 3inch mild steel catback installed
$7000 with no Gramlights or kakimoto catback (stockies will be provided and mild steel 3inch catback)
Mods:
3A Racing Air filter
JJR Split dump pipe
HPI front pipe
standard cat + test pipe
Kakimoto regu 06&R cat back
Splitfire coilpacks
ISC N1 coilovers
Cusco castor rods
Kazama tie rod ends
JJR front camber arms
Hicas lock bar installed + all lines removed (15-20kg all up)
Cusco 3 way rear strut brace
Nissan standard front strut brace
Road & Race 4wheel aligment
Exedy Heavy duty clutch
Nismo reinforced clutch pedal bracket
DOT 4 fluid flushed throughout all the lines
Nismo Radiator cap
Nismo Oil cap
Excedy small battery
Full coolant flush throughout the cooling system
Dba cross drilled and slotted rotors FRONT
Dba vented rotors REAR
Bendix ultimate pads all round
Break fluid flushed with DOT4 fluid through every corner
Gramlights 57D 17x9 +22 offset all round in matte white finish
Falken Azenis RT615 225/45R17 at FRONT
Yokohama A.Drive R1 235/45R17 at REAR
Rear fenders have been flared to clear the wheels, while this was being done the paint cracked on the rear fenders, as i was planing to respray the car i primed up the right hand rear fender, roof, rear bar, side skirts and also a section of the left rear fender! didnt do the whole left rear fender as there is a tiny lil rust spot that needs taking care of!
Before roof was primed
Note the side skirts and rear pods aren't on in the pictures but they will be gone together with the car!
PM if interested and/or looking to negotiate!
https://www.sau.com.au/forums/topic/301610-r32-gtst-in-sydney/
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
