HEY GUYS FOR SALE IV GOT MY VX CALAIS
SILVER IN COLOUR (SERIES 2 2002)
BLUE LEATHER (ELECTRIC SEATS)
DUAL ZONE CLIMATE CONTROL
FULL ELECTRICS
10 PUND M.A.C.E PULLEY
BODY HAS DONE 180,XXX KM'S BUT MOTOR WAS ONLY REBUILT 500 KM'S INCLUDED IN THE BUILD WAS THE BLOCK CHEMICAL DIPPED NEW CAM AND BALANCE SHAFT BEARINGS, BORED OUT CYL 20 THOU, ALL NEW WELCH PLUGS FITTED, LAPPED IN THE VALVES, FITTED NEW VALVE STEM SEALS, GOT A SECOND HAND CRANK AND HAD IT LINISHED AS IT WAS PRETTY MUCH SPOT ON, FITTED ONE NEW GENUINE HOLDEN ROD, FITTED NEW HYPERTECH PISTONS, ACL RACE SERIES BOTTOM END BEARINGS, HASTINGS RINGS, NEW FULL ENGINE GASKET KIT, NEW REAR MAIN PLATE, NEW FLEX PLATE TO CRANK BOLTS NEW MAIN CAP SIDE BOLTS, NEW BELTS, PLUGS, NEW CRANK ANGLE SENSOR, ALSO SERVICED THE TRANS WITH NEW OIL AND FILTER.
OVERAL CAR IS VERY VERY CLEAN!
ASKING $13.500
CONTACT JASON ON 0401-749-768 WILL SWAP FOR A CLEAN NO HOLE CUT SKYLINE WITH CASH ADJUSTMENT.
https://www.sau.com.au/forums/topic/301619-vx-calais-supercharged-6/
  • 5 months later...
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
    • My son recently purchased a 93 Skyline GTS25 (NA), I am hoping to get some insight as to what potential this car has.  I have auto mechanical experience, and I am capable of working on this vehicle, but I know nothing about it.  Where's the best site to purchase parts (maintenance, repair, upgrades)? What kind of upgrades are available?  Thanks again and I look forward to any information that you all have to offer!   Darrick
    • This is a pump I have used in the past; no oil ever leaks or gets past the regulator plug.I was trying to understand what caused Nissan to not only mention it in their manuals but to also state it's a replacement part yet the part cannot be found on my pump or on any new pumps and there doesn't seem to have ever been a replacement part#.  First time I've noticed something strange like this from NIssan.
    • yeah I have brown peeking out from in between some metal sheets close to the hood hinges. Strut towers look fine, even around the edges. some images https://imgur.com/a/brGt3Tu the one that looks the worst is the panel(s) going away right near the firewall on the passenger side, from underneath. Driver side does not look that bad.
