WRECKING 1995 R33 S1 GTST MANUAL, MAROON
100% COMPLETE RUNNING CAR NO DAMAGE, GEARBOX SOLD ONLY
ENGINE COMPLETE PERFECT WITH ALL ACCESSORIES $2500
x4 doors 4dr $100 each
x6 window regs and motors $100 each
front and rear seats $100 each
dash $150
cluster x2 $100
x8 seat belts $50 each
bonnet silver(small bend in rh corner easy fix) $100
bonner maroon perfect $150
headlights $150 each
rh 4 door tailight $100
x2 doors 2dr $100 each
grill $50
front bar $150
gaurds x4 $100 each
side indicators x4 $50 each
front indicators x4 $50 each
drivers window switch x4 $ 100 each
passenger window switch $50
rear window switches $30 each
door windows $50 each
mirrors x4 $70 each
door trims x4 $50 each
rear floor mat 1 piece $50
overflow bottle $50
washer bottle $50
ac condenser $50
power steering rack $150
front k frame $150
rear k frame x2 $150
front castor rods $50 each
control arms $50 each
struts and springs $200 pair
front calipers $200
front and rear discs $40 pair
front and rear hubs $100 each
rear calipers $150 pair
x2 auto tailshafts $50 each
manual tailshaft $150
fuel tank X2 $150
drive shafts $70 each
diff manual $300
turbo back exhaust stock $200
stock air box $200
stock afm pink $100
stock ecu $50
climate control box $50
boot lid $100
tail lights $100 each
series 1 used coilpacks $100 set
series 2 used coilpacks $100 set
series 2 new jjr coilpacks $500 set
PLEASE PM, SMS OR CALL 0424144636 LOCATED IN EPPING MELB TOO MUCH TO MENTION I HAVE EVERYTHING
  • Replies 48
Hey mate, do you have the large plastic cover that sits under the steering wheel, the one the fuse box is located in and the fuse box cover, if so how much and what condition?
Do you think I could grab a drivers seat belt, centre console from the ashtray/cig lighter back and driver and passenger floor mats. Would shipping be a problem?
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
