I replaced both the exhaust manifold heat shield and the exhaust housing heat shield with a custom one piece one. Much easier to get on and off and looks a lot better. If you can't get the stock ones to fit just make your own, but definitely worth having on there to keep under bonnet temps down.
First hand experience - I didnt think it would make any difference when I put my hybrid turbo back on. I left it off for a few weeks and noticed the engine bay warmer then usual... I put the heat shield back on and it was much much "cooler".
Best part about it is that it hides the snail pretty well and makes it look stock.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
