Im about to order some rims from japan (streeter)
And i dont know what offsets to get. My 180 has had a 5 stud conversion.
Does any one have some 17x8s and 17x9s that i could test fit to my car and work out offset needs from there???
As im looking for a flush fitment, not sticking out past the gaurds... Sick of getting hasseled..
Any help would be great
https://www.sau.com.au/forums/topic/301786-help-wanted-rims/
Dave was selling his wheels.....those meshies look awesome.....PM him
still am. with tyres too for a little extra.
yer just dont want to order them in and find they sit out to far.
youre welcome to throw mine on for a test fit mate.
Edited by scandyflick
offset (the 37) is mm. ie, the mounting face for the wheel sits 37mm towards the outside face of the wheel from the centre line. if the offset is -, then the same is true, but its towards the inside edge of the wheel.
as for how theyd sit on a 33... cant tell ya. lol.
Ahhh thanks for that
Apparently i have 9JJ rims on the rear of my R33 - 17x9JJ, and offset is *grumbles as he walks outside into the heat, and has a look at the sticker on the rims*...17x9.0JJX17 +35, whatever the JJX17 means.
jj is width
et is offset
ok, so mine is effectively saying it is 9.0" in width.
Mine are +35 on the rear and sit a little bit inside the guards, so i would say +37 will either sit flush...or just outside, but don't quote me on that.
^^ increase the number and it will sit inside even more
as a reference 9.0" +12 is a nice GTR offset R33 GTSt are also close in swallowing that size rim too i have drifteks in 8.5 and 9" +35 and both front and rears sit in the guards more so on the fronts which are 8.5"
i run 18x10 + 20 on r33 with rolled guards and lots of camber in 9" id say you would be looking at somewhere between +18 to +25 depending how you want it to look.. id say 9.5" is better option with maybe +20 or 25
forget +37 thats saw blade offset.
as for a 180sx jump over to ns.com they have a 300 page thread will be able to sort it out pretty easily.
Probs is its not as easy as saying, well hes using these offsets so itll fit mine. As ive been told 5 stud conversions can be all different depending on what parts have been used etc... Been told its just easier to try them on but cant from jap
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
