M35 Nissan Stagea Forsale
STAGEA M35 2002 250T
The car features "NISMO" options including gauges and body kit, "RECARO" front seats, after market Japanese alloys, flip down roof monitor, centre console has a "minidisc" changer in it, automatic fold in mirrors, dual sunroofs, factory reverse camera with dash monitor, Japanese immobiliser, near new tyres, tiptronic semi-automatic transmission, traction control awd, the engine is a factory 2.5l v6 turbo, recently having a full high flowed turbo upgrade in October 09 costing close to $5000 with receipts to prove these details, I also have the original factory front seats. Im the 1st owner in Australia as I imported it myself, very fast and practicable wagon in very good condition. 82000kms Any questions happily answered. Jason 0407710085
$20999
$20999
Unfortunately I cannot respond to "PMs" due to not having enough points or something on this forum
$20999
**********PRICE DROPPED TO $19999 NEGOTIABLE****************
Hi all forgot to mention the vehicle will come with genuine "NISSAN" rubber liner for rear cargo area. Which can come in handy if loading dirty goods in the vehicle. Also saving you from soiling or damaging carpet. The rubber liner is readily removable, and rarely needs to be in the car unless your carrying dirty goods.
Hi, I spoke to you on the phone yesterday.
Could you send me the auction report?
troy.kershaw at gmail dot com
Thanks
Hi there Troy just got home, ive had a look for the auction report. The result was i couldn't find it, but did find the "vehicle identity report" (south australian) identity check for rego after the car was complianced. Also have compliance paperwork plus "vehicle import approval" forms from Australian Government.
Hi, me again.
Is the exhaust standard?
Have you had it tuned to run on 98 fuel or after the turbo upgrade? Can you attach/send the dyno sheet?
Cheers,
Troy.
The exhaust is standard except for the tip. The rear muffler has "nissan" stamped on it. The rear muffler also has a factory electric actuator, with factory switch inside. The switch reads :silent /sport. I personally cant hear the difference. You can hear the actuator operate from outside when switched tho. Having said the exhaust is standard, it still makes a decent note under load, but doesn't drone when cruising. As for a dyno sheet Ive never really been interested in power figures etc, as this is my 2nd car/daily driver. After turbo upgrade I had a "sniffer" test to ensure correct air fuel ratio's and to check the engine didn't "lean out" on boost. Car has never been ran on at standard unleaded always premium as these engines were never designed to run on our standard octane unleaded, as Japan's fuels are far better and higher octane.
 Share
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
