Hi folks,
It's with a heavy heart I sell my baby: the a/d/s/ P850.2 Powerplate amplifier.
I purchased this amp about 2 months ago from a CAA member and only want back what I paid for it seeing as I didn't use it.
The previous owner used it sparingly (less than 30hours) and it is in excellent condition. The amplifier comes with original packaging and manual. The only reason I am selling is because I'm going to Tru Technology which is an upgrade in anyones language.
The retail on this amp was/is $2500. I am selling it for $875. If you want a single amp to power everything cleanly with quality in a low profile chassis, this is for you.
Specs and pic below:
P850.2
What could be more space saving and installer friendly than an eight channel amplifier that creates 50 watts per channel, into a 4 ohm load? The answer is "nothing", but add to that a bridgeable power supply that is 2 ohm stable, our Multi-Cross™ crossover, and you have a unique unit that can excel in any automotive environment
watts/ channel 4 ohm: 50x8
watts/ channel 2 ohm: 75x8
watts/ bridged 4 ohm: 150x4
THD: 0.10%
S/N ratio: &90dB
bandwidth: 10-30kHz
damping factor: &150
input sensitivity crossover frequency/ slope: 100mV to 10V 45-5kHz/ 12dB
dimensions: 330mm x 50mm x 410mm
http://www.adst.com/products/mobile/ppamp/p850.asp
This is for the SQ purists and extremely rare.
I will ship anywhere within Australia at buyer's expense.
https://www.sau.com.au/forums/topic/30181-ads-8channel-amplifier/
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
