Good to see an R33 GTS run 12.3 on wed night with 306rwhp on good rubber.
This car was only a 25/40 bolton turbo, Wolf plugin ECU, intercooler + exhaust.
Can't wait to see ND4SPD run now it has 280hp more than this GTS at only 21psi and soft timing,we have left it soft because we have to race Tango1 on tuesday at the plex and didn't want to upset the commish of police.Then we can put good fuel in and crankit up.580 is the highest power run by a GTR on a Shootout accredited dyno in WA sofar!
https://www.sau.com.au/forums/topic/30182-whales-revenge/
  • Replies 65
Make me a coffee and i'll tell you.
Wait till the 2 Bar runs happen next week but remember that this power was in Shootout so don't be suprised when Ant beats "Higher" powered GTRs.
Wheres the Cams Toddler?
I drove ND4SPD today,F--k the 9000rpm limiter hits very fast in the first 3 gears but my balls gave up after 3rd. Ant wants to tune to 10000 after the Tango1 PR day because the power is still climbing at 9000.Wolf ECUs rock.
https://www.sau.com.au/forums/topic/30182-whales-revenge/#findComment-613402
ND4SPD ran at the plex today.
Ant did one recce run then went out for a big go but the Gearbox spat the dummy.The good news is that the car ran 6/10s faster to 500ft than its low 11s best so a 10 is a walk in the park if we can get a box to do 1 pass but the Dog box has just gone to the top of the list.
https://www.sau.com.au/forums/topic/30182-whales-revenge/#findComment-616695
    • There's more than one way to skin that cat, and most of the sump Maatouks have done will be GTR sumps. They are HUGE in GTR drag racing here.
    • Yeah...I always start at the shift solenoids, because there's only a few reasons these will spook into limp mode, and bad shift solenoids is one ~ the other can be the shift control module (if you have steering wheel shift buttons)...it's easier to eliminate the solenoids first.
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
