Both S2 healights good nick halogen globes - $400 set
Cat back straight through kakimoto exhaust rough but still does the job - $150
Power FC hand controller only- came off pfc for s2 33 - $300
s2 r33 rear view mirror - $20
s2 r33 gtst front seats (small hole in drivers right wing) - $150 pair
s2 r33 cluster (tacho speedo temp fuel etc etc) 117xxxkms - $200
Set of standard wheels nuts for 33 skyline - free with any purchase.
I'm contactable via pm or on here.
Located in the hills area
Cheers,
Greg
https://www.sau.com.au/forums/topic/301824-few-s2-r33-parts/
Lights are in good condition no cracks anywhere halogen globes LED parking lights, plastic is clear. small bit of white maybe 1cm by 2mm inside the light that is white instead of black harldy noticable in one of the corners. Feel free to send your number and i'll send a pxt
all pm's replied.
PFC hand controller serial number is fcc3 020-11199
I've seen them sold seperately before so as far as i'm aware they are interchangable. Unless someone knows otherwise
Hand controller received and top notch. Cheers for the extremely quick postage.
Good to hear, thanks mate.
HEADLIGHTS SOLD PENDING PAYMENT
REARVIEW MIRROR SOLD PENDING PAYMENT
EXHAUST AND SEATS STILL AVAILABLE
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
