Hey guys, In the past couple of days my clutch started going wierd, the friction point felt lower than normal, but it still drove fine.
on sunday, took it to the gf's house in the afternoon and while parking, noticed it became hard to get into gear. so i left it for a few hours, came back and it was fine, drove it home.
Now I left it there for a day and a half(didnt needd to drive anywhere).
I got up for work yesterday, started up and it wouldnt let me get into gear at all! /the clutch felt wierd as well, it lost pressure to the halfway point had a bit at the other half, but still didnt engage the gears. I left it there and after work came to have a closer look. found my master cylinder was empty so i bought some clutch fluid, put some in to the max point while the clutch was stepped in. didnt make a difference. I looked under the car and noticed a leak on the right side of the gearbox (slave cylinder i assume).
now the clutch has no pressure at all, it will drop all the way to the bottom and not come up(needs to be pulled up). what do i need to do? will i need a new cylinder or can it be repaired?
Bad time of the year for my car to do this,,I was meant to go away today..dnt think thats happening:(
https://www.sau.com.au/forums/topic/301875-help-clutch-died/
the part is cheap, i cant recall the number off the top of my head but they are between 12-19 from autobarn or repco. (rb20 is same as sr20 and is the 180b part number jb4055, r33 P/N i cant recall atm)
Yeah the two possible part numbers are K791S and K1008S
Also I'm pretty sure the JB4055 doesn't fit the RB20 Trent. They bolt up and work but the pushrod is usually at an angle which causes the cup seal to wear out within 6 months.
I think the number you need is JB4184. I could have them around the wrong way though.
Neither of those part numbers fit an R33 though. The slave cylinder is genuine only for an R33
good job ^^ your memory is better than mine :down: i can now only recite blitz and trust catalog part number off the top of my head.... used to be the bendix and md spares books aswell but now there is no chance :P
Hey guys, thanks for the replies. Anyways, I checked it again yesterday and suddenly, the clutch had pressure in it again. It took most of wat was in the master cylinder though, so i topped it up.,,ran fine for a while but died on me a while later, after a few pumps of the clutch it was good again. I think the slave is still leaking tho so im takin it easy till i get the slave replaced. Thanks for giving me the part numbers, will make this a lot easier. Let u kno how i go, Happy new year guys
Ben
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
