Last night i was driving home from my cousins house and all of a sudden when i was not accelerating and my car was slowing down it was shaking and i was feeling a bumping coming from the front right hand side wheel as i go quicker it would go away but soon as i stop accelerating and just cruise and 60k i would feel shaking when slowing down or just a bumping when cruising at 60k.....
Im thinking it may be a crushed wheel bearing but im not 100% sure has anyone else had this problem or has some input to what it may be.
My car is a Nissan Skyline R33 GTR
https://www.sau.com.au/forums/topic/301901-car-bumpingshaking/
you'd think that if it was a wheel bearing it would get worse with speed, and it would also get worse when turning left (more weight on the right hand side when turning left).
it may possibly be an enginge mount, or the car has a missfire at light load. if you can make it do it on command, next time you are slowing down and it is doing it, push the clutch in. if it goes away then it is engine mount or a missfire. if it is still there then you may be right about the wheel bearing or it may be a uni joint of even a CV joint/shaft
i had a magna once with a shagged main engine mount but my vibration problem was the reverse of yours. at about 90kmh if you put your foot down it would shake the shit out of the car. even cruising at 100kmh was enough load on the engine for a small vibration but if you put your foot down just a fraction, like to go up a hill it would shake like hell. new engine mount fixed it, and the old mount was totally shagged.
If it doesn't happen all the time, but does happen sometimes and especially if you hit a series of bumps that trigger it then its likely to be your power steering. Not sure if the Skylines have one or not [and I CBF looking atm, and I've never needed/had to do it on one] but there is usually an adjuster on the power steering box, a screw and lock nut. Get your wheels straight, undo the lock nut, screw the adjuster in and out until you feel and know how it seats and then adjust it to firm, a bit better than finger tight, but not gorilla'ed. Usually seat it neat and then another 1/8 of a turn will do, lock it off and problem should be solved.
actually that reminded me. a mate of mine had a s13 that had a shagged pump and whenever you turned the wheel the car shook. have also seen it happen in a car with low power steering fluid and went away when topped up, but again, it was only when you turned the steering, not when just driving.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
