Item Summary: Nissan Skyline R31 GTS-X Coupe - 1986 R31 Coupe - VG30DET Conversion!
Condition: Used
Reason for Selling: Lost Interest
Asking Price: 10500
Delivery Methods: PickUp
Contact Info: PM Me for additional info
Extra Information:
Hi All,
I no longer have space or time to continue this project.
The following are the specs and information on what has been done.
PERFORMANCE MODIFICATIONS
*VG30DET - (STANDARD flywheel figure as quoted by Nissan Japan = 190kw @ 6000rpm & 343NM @ 3200rpm - using no intercooler)
*Custom heavy-duty engine mounts to suit
*VG30DETT 5 speed - Z32 300ZX, VERY strong gearbox, similar to R33 RB25DET gearbox internally
*Exedy Single Plate Brass Button Clutch
*Custom balanced 2-piece tailshaft for high RPM/High Speed durability
*APC (Advanced Performance Centre @ Underwood) Replacement intercooler - good for 600HP
*ALL aluminium inlet and intercooler pipework - heaps lighter than stainless or mild steel
*New K&N Pod Filter
*Upgraded 550cc O-Ring Injectors on custom rails
*-6 Billet fuel pressure regulator
*Polished Alloy Oil/Air Separator
*New R31 Aussie delivered radiator
*AU Falcon Thermo Fan Assembly
*4" into 3" turbo dump pipe
*3" exhaust system with high flow cat
*Reconditioned Steering Rack
*5 Stud conversion
*Nissan 4 Spot Front Calipers R32
*Nissan 2 Spot Rear Calipers R32
*Pedders "Sports Rider Suspension & Springs"
*Haltech E6X ECU - Fully wired and neatly installed
*GM LS1 Coil Pack + Leads
*GReddy Turbo Timer
****************ALL THE ABOVE IS MOD PLATED *****************
INTERIOR MODIFICATIONS
*Trust Gear knob
*Sony CDX-M800 Head unit
* JL Audio 6.5" splits (front)
*JL Audio 6"x9" (rear)
*VDO Oil, Water, Shift Lights
*Autometer Boost Gauge
EXTERIOR MODIFICATIONS
*Parabola Headlights
*Front Bar Modified to suit FMIC
*R32 GTR 16" x 8" rear rims painted in RAYS Engineering Bronze
*R32 GTS-T 16" x 6.5" rims painted in RAYS Engineering Bronze
Asking Price $10,500 ono - No swaps please.
For more info PM me.
Tim
https://www.sau.com.au/forums/topic/301924-nissan-skyline-r31-gts-x-coupe-1986/
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
