  • Replies 521
f**k yea, 104 in a 60 zone :3some: i was gonna go for a run but it was a pusute car so i thought i better not, but the cop was ok, he said he saw me in the 80 zone when clearly was not but i wasnt gonna argue with that... $210, oh well, paid it about 20mins after so its all good
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3053823
well found out in the last two days im either comin back up there or too brissy at the end of the year my job prob wont be here at the end of the year, so the sinista plates may grace my car once again, this time i will be back with avengence (hmmmm 320odd rwkw) hahahaha i have to wait to find out lol
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3063704
Hey ill be in Darwin from 21st of June to 3rd July.
How about a cruise on the 30th so i can have a look at some Darwin Skylines???
I can participate in the cruise in either a 4wd or Hyundai! (Dont judge me, its not my fault) LOL
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3134954
if you want that , you will have to post in the NT section of Boostcrusing.com , as there are not enough skylines to keep this part of this site running , there are some very nice lines up here so I hope it happens
Cheers
Jaqule
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3136793
26 the 31 Zac, pron!
I have thought about it but its a bit of work... was guoing to do a 25 because they're not so much work. But looks like i could have another RB30 soon, and it wont cost me jack so i'l probaly do a crazy RB30. :sorcerer:
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3153920
    • I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket.  On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense.  So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
