  • Replies 521
Ken my bestest friend old buddy old pal ......
Can you get my: - Electronic boost controler for power fc.
You know the car details - here is the serial no. of power fc if required.
s/n - PFC ecr33 010-1563
cheers
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1856981
Hey boys currently overseas but now have wireless to the net so can keep up to date! Just wanted to let you know nuffin werks that camp smitty is a frezzing shit hole at the moment.
Also Ken can you get a hand controller for a power fc as i've already got the comp just need the hand controller for dyno tunes? If so how much?
Cheers stevo
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1868931
hey efteoh, jay told me something about you reckon its easyer to remove the head to get the No.6 exhaust manifold studs out.
Sounds like a lot of hard work and dollars. Is there anything else you can recommend to remove them. and getting standard ones from say nissan etc should be fine yeah as a replacement ?
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1907262
Well for those interested , i found the perfect tool on thursday to drill holes in the exhaust manifold studs that were broken off so i could get the screw extractors in to remove the studs. Anyway it cost a little bit for the tools etc etc but well worth it to not have to remove the head just to remove one stud.
The project is well underway with only a few more parts still in transit (frieght is so shit here) and the Whale will be back on the road again.
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1925726
  • 1 month later...
  • 3 weeks later...
    • Not sure what you mean by electronic speedo drive.  Speedo reads fine up to 180 yes.
    • For anyone interested, this is my old graph from 2021, but I've plotted the previous setup curve onto it with a black pen. old setup was: pon cams, oem itbs and plenum, HPI manifold, hks 2835 pro S .87ar rear, Turbosmart actuator, 3" turbo back no res. or cat., greddy spec M fmic, nismo 740cc inj, walbro in tank 460, splitfires, 4" intake pipe, Apexi pod, e85, eboost2, power Fc. I love that the new setup has much larger turbo spec with the HTA3076 1.01ar Ts rear, and literally everything is bigger, but far higher quality and result is it's FAR more responsive in paper.
    • This makes a lot of sense! I just had that realisation a few minutes ago and wrote it above haha. This is a good new discovery. "Sanding the side of the hill" perfect way to put it.   馃槀 馃槀
    • This is probably what's happened to me. I'll put filler again on my repairs and use the long block and let you know how I go. Fingers crossed it's my last batch of filler lol. I can see that happening where my block dipped at certain points because it didn't cover all the high spots at the same time if that makes sense. I'm just trying to visualise the fact that with the large sanding block I will be sanding far away from the central dent area and whether that will cause issues or whether that's going to fether out my repairs better.
