Hey guys, i have an embarrasing questions.... Here it is
I brought myself a 1993 Skyline R33 Gts25t and noticed 2 buttons that say spoiler up and spolier down, the spoiler down button is under the spoiler up button they are sitting in the dash just to the left of the steering wheel, when i press the buttons i can hear a, eletrical motor run but i dont notice anything happen, the switches look like they are factory not after market so if anyone could tell me what they are there for i would be thankful
Thanks guys
https://www.sau.com.au/forums/topic/30198-strange-buttons-in-dash/
mind you if you have an aftermarket front bar or a bumber that was repaired after an accident, those switches are as useful as tits on a bull.
If they don't do anything I suggest you rewire your amps remote volume control to those switches... go for that factory look. :D
as far as i have read they were an option on 31's, 32's & early 33's. the buttons on the dash only work when the car is on, stationary & with the handbrake on. otherwise it comes down automatically at around 75km/h & will stay down until u click the up button in or drop below 50km/h.
mine still works & is the only one i've actually seen operate.
