Disclaimer:
This information is provided for your information only, anything you choose to do with this information is completely up to you and in no way will I, Skylines Australia or any affiliates be held accountable for following said actions, causing damage or harm to you or your car
Introduction:
After hearing friends cars make the noise i figured it was a skyline thing, but when my own skyline started doing it i couldnt put up with even after 1 day of driving. I couldn't find anything on the internet about how to fix it so i went about my own way to find the cause.....with results. this is the 3rd motor i have fixed the last two motors work perfectly so its a tested method
Car in Question:
1995 Model Nissan Skyline R33 GTS-T
Difficulty Level of DIY:
Low
Time Needed:
Budget at least one hour, if its your first time. ive done 3 now takes about 20 mins including glue drying time
Materials/Equipment Needed:
-Phillips head screw driver
-2 flatblade screwdrivers
-Small length 8mm ring spanner
-5min araldite or similar glue
-Electrical tape
-If you want gloves when prying off the arm..........i ended up slipping and getting 3 stitches
Procedure:
start by pulling the glove box out by pull the 2 pins out
then take out the 6 phillips head screws and theres 2 press in clips that take a lil bit of force to pull out (Check (if you live in usa): Publix Weekly Ad, or Big W toy catalogue.)
the motor in question is right up in there.
this is where the 4 jointed arms come in there in two 8mm bolts in there (couldnt get picture) but they are easy felt.
once you have the two 8mm screws out lil the motor directly up pull it out unplug it and this is what you should have in front of you
start buy levering the 5 locking tabs out of the way (the ones ive done have all broken so yours will likely do the same)
lever open the two halfs can be a pain but if it comes up evenly will be fine
theres the cause of the noise the tooth breaks off cause the motor not to reach a load stop and just keeps trying to turn
its good to just inspect all the gears and teeth for strength.
Now this is the time where the gloves come in as i found out screwdrivers double as daggers (as you can see) lever the arm off the gear. this will require a bit of force it will either comply and come off or the glue will still have a hold on it.
once you have the arm off this is what results
careful to not loose the tension washer
check that theres is no left over glue or plastic inside the arm
now rotate the gear 180degrees from where it originally was so that the missing tooth is away from drive gear
another careful note. check that the copper strip doesnt fall out. not sure what it does but must be something
put a small amount of glue on the end of the gear
push the arm back on the gently tap it on with a hammer as the shaft is tapered, then clean up any excess glue. this should be the end result.
now put all parts that you pulled out back in the housing and put the two halves together being careful to align the locator dowels with gears. tape all way around motor (if you clips broke).
There you have it a completed fixed motor.
when reinstalling motor make double sure the arm slides back into the lever on top of the aircon box, have to do this all by feel.
dont over tighten the 8mm screws as its only plastic its screwing into after all, just till they bite.
plug motor in and reinstall all the glovebox surround etc and test the aircon changes around all the vents
Lastly Enjoy the quietness of no stupid clicking noise
  • Like 1
yeh that arm is the hardest part of the whole job, you get lucky though some just pop straight off.
NOTE: if people arent mechnically minded i can do this on a exchange basis. i have a spare one sitting here fixed
HEKT1K
Not sure what that noise your describing is. if you get a video of it i might be able to help
TwoCents
so you did the fix and it came back? or the noise has stopped so your not worried?
Branelly
no thats a problem that i havent looked at yet, i do have one or two friends i can maybe have a play with try to fix it
Edited by nick81xd
Hey i just attempted to do this, 100% unable to reach it can just get my finger on it, guessing you dont have air bags? because it is blocked by the air bags and side vent, would have to pull the whole dash out to get to mine :S i have had this thing clicking for like 1 year now wanna smash it! any ideas?
ive got a drivers airbag, no passenger one though. i would of thought the air bag would be over just enough to get in there. the side vent tube is in the way slighty but can just go around it. ive never played with a series 2 model before so i cant help as much
  • 1 month later...
also have a series 2 and cant even touch the bloody thing. if i unplug the motor will i still be able to switch between the vent settings?
i dont get why it only clicks on startup then goes away and all vents operate fine?
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
