As above, mine works perfectly but gives the noise on startup only.
I just pulled a unit out of a half-cut (my car is in bad shape atm) and it looked almost impossible without the dash off (which I have to do anyway to change my airbags)
I'm going to try giving it power externally to see if it's any good, otherwise i'll try the above mentioned trick! =-]
it took bot an hour on my series 2 with the airbag its possible if you undo the bolts on the middle and left air con box and pull the middle one down off the otheres i have big hands and still got up there the first bolt is easy the front bolt what you need to do is have the small 8mm spanner and manover it from the front but behind the baig bar brace thing and turn it bout twice then just use one finger from ech hand and unscrew then its out im now gna do the rest and put everythin back
hey guys,
just got the motor out of my S2. just thort i would throw up a quick post recommending having a go at the screws using a 8mm socket piece (just the socket) instead of a short spanner (i was about 2seconds from attacking my ring spanner with a 5" before i decided to have a go with the socket)
also, what exactly does this motor do? you say it controls air vent direction, but currently the motor is out of my car and i can switch between modes and it changes the air flow to the selected vent as intended (main, feet, window, etc). AC also works fine and i can change temp range aswell :worship:
I have a series 2 and have not made any progress in being able to get to the motor. I found 4x 10mm bolt screws and removed them. After that, I'm not sure what to do next. I seems this whole box (air con?) assembly needs to come out so that one can get to the motor. Have posted some pics.
I'd love to fix that horrible clicking sound, but so far this is as far as I've been able to get.
confirming, this DOES work on a series 2 with passenger airbags!!!
As previously mentioned you need to undo the condenser air box and fan box to the left, shift the fanbox a few mm to the left, then pull down on the condenser, it will 'pop' down, giving you ample room to get your hand up there. Do not try and remove the condenser as there are pressurized pipes for the aircon in behind the box.
When you put the condenser back in, just remember to check the seals between the firewall in the engine bay and push them back in as that's what 'pops' wen you pull down.
I used a tiny 1/4 ratchet, thumb phillips screw driver and a 8mm spanner to get the 2 bolts off and on on the motor.
My motor was pretty damaged, there were teeth missing from both gears as shown in the OP, flipped them both round 180, bolted everything back up and works great!
KrazyKong, you are almost there, undo the unit to the left of what you have undone and keep going :cool: there are 2 nuts and 1 bolt holding the fan box on :)
KrazyKong, you are almost there, undo the unit to the left of what you have undone and keep going :action-smiley-069: there are 2 nuts and 1 bolt holding the fan box on :)
ok, thanks for the info. Will give it another shot.
For the longest time, I've heard some sort of rattle up in my dash, and I could never find what it was. When I took a corner, about half way into the corner, I'd hear something sliding around. I have a hunch there might be a loose bolt or washer inside either the left circular fan box, or the condenser box. Is there anyway to actually open them and look inside? Other wise maybe it's in my passenger side door, but I the more I look at these boxes under the dash, I think it's inside of one of them.
  • 3 weeks later...
After spending 4 hours on this today and having nothing to show for it, to say I'm in a bad mood is an understatement. I don't know how you guys managed this, but in my car there is simply no room to manouever my hands let alone be able to remove the noisy motor. So right now I'm just going to take the whole dash off. I feel dizzy and nautious from my neck being creaked and looking up into that gap. This is not an easy task for a S2 with airbags. Do this at your peril or you'll find yourself getting to the stage you'll want to willingly break something.
Ended up getting the whole dash out. Then proceeded to replace the noisy motor. I took the airbag fuses out of course and disconnected the battery. Then upon firing it up, the sweet noise of nothing. No horrible tock tock tock sound, well so far anyway. I hope I have damaged anything from my earlier venture of trying to get the fan and condenser boxes out before I realized they were attached via pipes from the engine bay. Time will tell. Knowing my luck, I fix something minor only to break something more important.
The light ran out so had to close up the car for the night. But first thing tomorrow, will then attempt to put it all back together again. I'm hoping to be able to peer inside the fan and condensor box to see if there is indeed a loose nut or washer that has been making this sound for ages. But so far I'm not sure how on earth it's possible, as both boxes don't seem to be removable without major headaches with piping, A/C gasses etc.
wow has this post been active. S2 is confirmed that it can be done. Took bottom aircon unit out, lucky i had no gass otherwise haha (im sure someone has done it, you know who you are)
Oain in the arse of a job, but honestly was only a matter of time be4 i put my fist through the dash
  • 2 months later...
  • 2 months later...
Hi,
I joined this site specially to post this message, im not even from Aussieland!
If you cant be bothered to fix this and want rid of the clicking noise, simply leave the fan setting on 'feet and face'. Once its set to this, the clicking wont ever happen again as when the car is switched on, it remembers the setting you left it on. I use feet and face 99% of the time so hardly ever hear it (unless I change the setting)
With regards to whoever it was who said the clicking noise gets loader/faster when revving... When the engine is off on my car, the clicking noise very slow and goes on for a while. But when the engine is running, its quick. Meaning the motor isnt getting all the power it should (battery not 100%??)
Sorry to drag this thread up!
Cheers,
Mark
Guys ,
I have a 96 gtst sII and i have just started to hear a repeated click but its not comming from the console it appears to be aroung the dash.. It does vary in speed as the motor revs and only when you are moving. After reading this thread i am more aware each time i get in the car (Dam it) crank the radio loader to disperse the clicking sound now as well...lol
Have you guys any ide? i whatched the odemeter & trip meter to see if the moved when it clicked buit i couldnt tell as they both appear to turn over fine....
Regards,
Darren
hey i have the same problem as one of the other guys on here, my heater is stuck on, no matter what temp i set it too.. and i believe its one of these motors..can anyone tell me were i can find it?
and di anyone firgure out what this motor from this topic does? lol
you need a new climate control unit to fix the stuck on hot or cold problem. only way i figured out how to fix it.
the motor in this topic as previously stated controls face, feet, windscreen etc vent control
  • 2 months later...
hey guys,
also, what exactly does this motor do? you say it controls air vent direction, but currently the motor is out of my car and i can switch between modes and it changes the air flow to the selected vent as intended (main, feet, window, etc). AC also works fine and i can change temp range aswell :P
I think it opens/closes the vents, though not sure if it does others. But I do know it opens/closes the big main vent that you see sliding up and down. This is the one above the stereo and the hazard switches. If you take the dash covering off that contains the hazard, demister and etc. switch on it off, you'll see a big vent covering. That's what it moves.
  • 4 weeks later...
+1 socket works well and awesome work on the writeup. Though I did drop the socket and it disappeared...... Was about 2 seconds from tearing the dash apart then thought to use a magnet on a piece of string which worked a treat!!! :laugh:
  • 1 month later...
Removing the whole dash is easier than you think. I've done it a few times now. Once you know where all the screws are, the hardest part is taking the whole thing out without scratching things. I gave things a nice clean when I had it out and also fixed a few others. End result is no more noise from the frog motor and silence :)
so im guessing this would be the same for a R33 GTR?
mine is also stuck on hot so could be a combination of climate control an this vent control which makes the clicking noise? :angry:
awesome write up also Cheers
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
