I wished that the air bag wasnt there when I tried to get to the 8mm bolts, but it is and the way I went about it was to read up Predators Dash removal and then instead of removing the dash I proped it up enough to get my hand in and used a socket with an allen key to twist it, worked for me and now NO more noise.
Thanks to all who contributed without your help that noise would of drove me batty.
Edited by R33S2
OK so i took the glove box out to have a look at this vent control box, this on a GTR
can only just see the arm that moves when you select different outlet(feet, face ect) but sounds like it doesn't move on all selections, is this normal?. When it does move to a different selction the air doesn't come out on that selection.
At first i thought the arm had come off but it look like it is still connected(im gonna bring a mirrior home from work to double check).
Also the cluncking/clicking sound gets louder then softer
ANY HELP/INFO WOULD BE MUCH APPRECIATED
Cheers
  • 3 months later...
This defeated me yesterday on a S2 R33. I loosed everything to get clearance but I couldn't get my hand in there far enough to have any idea what needed loosening. For me I would need to loosen the dash and lift it up to see what I am doing. I cbf taking the dash out after spending 1.5hr under there trying to get it loosened and tightened back up. My neck said enough was enough.
if any one has a spare one I'll take it! I couldnt get the arm off either, applied too much force and it shattered into a million peices.. tried superglueing the lot but it was just a fail so i binned it.
Any help appreciated :)
Cheers!
Just removed the motor myself today.
I took some pictures, so I could see what it was I was trying to pull out. Figure it might help some of you.
1st pic is front of the dash
2nd pic is the actual motor itself. You have to wedge your hands in there to touch the motor.
I used a small 8mm wrench. I found it easier to remove bolt 1 of 2 with my right hand by just crouching in front of the car.
Bolt 2 of 2 I actually lied down on the passenger floor, so my face would be facing upwards and I used both hands to loosen the bolt.
Any other tips other than grease to prevent the gears from chipping again??
  • 3 months later...
geunine item is $250 PN 27736-70T00
dash removal is about the only real way to do it. I looked at it with the idea of accessing it WITHOUT pulling the dash - pass. dash out is far easier.
  • 1 month later...
did in my s1 r33 it works great no more noise :thumbsup: took me about half an hour
but +1 for the wearing gloves because you WILL stab yourself with the screw drivers!!!
also you can get all the clips of with out breaking them you just have to work your way aroundwith a small screwdriver untill it comes apart...and be very patient :/
  • 2 months later...
I had my dash apart for other reasons and swapped in a low k's halfcut item while I could. Problem solved. I did try and fix the old one, but that arm was not going to budge.
Now the one for the heater/air is dead. It started out with clicking, as it started not knowing when to stop. Now I think it's broken a tooth off the gear because the clicking has gone, but sometimes i'll get mad heat when it's set to 18 degrees with or without AC. The temporary fix is to up it to 32, then back to 18 and it seems to move the flapper and then it's all cool again.
Anyone know how to change that one? I'm not taking the dash out again! ;o)
The original noise happened when changing modes from face/feet/demister etc, so I assume the part we are changing here is the "mode" actuator in the attached pics. From memory, it seemed positioned more like the Mixer actuator. The noise (when it started) was closer to the drivers side for the second actuator issue... which appears to be the "mode" actuator. Makes no sense that way around though!
Yeah i have the issue with hot/cold with my r33 S1 also. had it for about 8 years now. in winter when i need hot, i up it to 32 degrees while car is on, i go under the dash on the drivers side, and i give the valve a helping turn, and it completes its cycle.
When i want cold in summer, i lower temp to 18, go under dash again and turn it back. been doing it so long now, its just normal for me now :)
in regards to this thread though, i also have the clicking issue so going to give it a go when i get home. I havent had face vents enabled in the whole time ive owned the car. When i eventually get it going, i expect 8 years of dust build up to blow out. :)
LOL!! That's pretty dusty! I get my aircompressor and the long nozzle blower and give it a blast now and then with the windows down and the doors open.
As for the helping hand, it sounds like the one we have the problem with is easier to get to? I haven't had a proper look yet.
Well i did this also. however, araldite not strong enough. the lever started to turn, then started clicking again until the lever snapped. tried it twice. maybe the rack where the lever fits into is caught else where and doesnt want to complete its full path.
ive given up for now, unless someone has any ideas
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
