Hi all,
I have looked far and wide but i still can't find what I am looking for.
Does anyone have a list of the codes that the control module for the A-LSD flashes out when an error is detected?.
On the underside of the module in the boot is a light that flashes codes in the same way that the ECU does.
Edit 'my car is a 1993 r33 GTS-T manuel.
Thanks
Ray.
Edited by guru_ray
https://www.sau.com.au/forums/topic/302002-codes-for-the-active-lsd-computer/
OK,
This seems to be a hard question.
If someone out there wants to do me a favour?
Moanie suggested in one of her posts she knew what one of the the codes was on her A-lsd module.
If somebody wants to send a PM to Moanie ask if she can post the codes here, if she has them.
Moanie if you don't have codes for the A-Lsd module where did 'read' the TPS error?
I cannot send personal messages until i have made 10 posts.
I don't see the point in spamming threads just so I can send a message.
If the answer is out there lets get it up here! :bunny:
Ray
ps. if you send a message to Moanie post you have done so, so she don't get a mailbox full of spam.
OK,
Ray
I don't know if you have seen This but it has links to other topics on the SAU forums that have lot of info on the Active LSD option in R33 skylines. Maybe try checking it out first. It may clear your error for you but doing some simple bleeding.
Deano45
Dead link for me?.
I have studied all the links in the sticky at the top of this section of the forums if that was what you were referring to.
I am trying to read the codes so I can get this thing working properly, I am single spinning at the moment.
And have two codes one is TPS the other I don't know.
Thanks all help appreciated.
Ray.
Stock ECU is in the car now.
Codes I have are 75 which i believe to TPS
And 62 which if the same as the Attessa codes would be front and rear right G sensor???? I don't think the GTS-T has G sensors???
Will be going with apexi powerfc later and splicing the wires for the TPS, If I get the A-LSD working that is.
Ray.
Deano45
Dead link for me?.
Ray.
Sorry try this link
The other link didn't post properly
What error codes are you getting?
The G-sensors it is referring to is the wheel speed sensors. This is what your ABS uses also, hence if you have an ABS fault, your A-LSD goes to shit. This becomes a problem when doing stand still burnouts and locking up the front wheels. The ABS sometimes gets a fault since the front wheels aren't spinning but the rears are and then the diff goes into single spinner mode. Hence not the best diff if you like doing stand stills.
And another piece to the puzzle fits in,
Always wondered why the car defaulted to single pegger when I did a brake lock burnout. Thanks mate.
Thanks I have read every thing there all the links.
Codes are 75 and 62.
Cheers
Ray.
I could be going down the wrong path but these are the codes for the Attesa ETS ECU in the R33 GTR.
The diff is the same one as the V-Spec, so I would assume that it would use the same/similar computer to control the diff & ABS.
Going off these codes 75 is the Throttle Position sensor. This normally looks for 0.5v fully closed. You can check this with a multimeter and move the sensor until it has that reading.
PM-R33 looks like he has covered the error 62
Error Codes:
1,5 Front right wheel sensor and circuit
2,6 Front left wheel sensor and circuit
3,7 Rear right wheel sensor and circuit
4,8 Rear left whel sensor and circuit
11,21 Front right inlet solenoid valve and circuit
12,22 Front left inlet solenoid valve and circuit
13,23 Rear inlet solenoid valve and circuit
15,25 Front right outlet solenoid valve and circuit
16,26 Front left outlet solenoid valve and circuit
17,27 Rear outlet solenoid valve and circuit
31,32,33 E-TS solenoid and circuit
34,35,36 E-TS fail safe solenoid and circuit
41,42 ABS actuator relay and circuit
43,44 ABS actuator motor , motor relay and circuit
45,46,77 ET-S/ABS control unit ground and circuit
47,48 E-TS/ABS control unit power supply and circuit
51,52 E-TS actuator motor and circuit
53,54 Pressure switch and circuit
55 Air bleed switch and circuit
56 E-TS oil level switch and circuit
61 FR and RR G sensor 1 and circuit
62 FR and RR G sensor 2 and circuit
63 FR and RR G sensor 1 or 2 and circuit
64 G sensor 1 power supply and circuit
65 G- sensor 2 power supply and circuit
66 Side G sensor and circuit
75 Throttle position sensor and circuit and sensor
Haha yeah, it is the most over complicated diff in history. I think one day im just gonna get rid of it and put a 1.5 way into it, it's such an annoying diff. Great when it works normally, but a pain in the ass when it decides not to work.
Ok wheel speed sensors, where the hell are they?.
I would have thought that they would be on the hubs, with a magnetic reader and a magnet spinning with the hub?
No wiring going to the hubs at all.
There are two sensors of some sort on the back of the diff itself ether side with two wires each. I followed these wires and they go to the Hicas Module.
Stupid diff.
On a side note I have a hicas lock bar. The wiring for the hicas does no need to plugged in to make this diff work does it?
Ray
Stupid diff.
Ray
Well done chief, that are they!
Any ideas on how test these for correct operation, is there a resistance test?.
Ray.
Nope HICAS does not effect the operation at all. Honestly i have never looked for the wheel speed sensors so am not sure.
They are definitely the sensors but I do not know where they go, can let you know tomorrow. But I suspect it may be of no use to you as I have a GTR.
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
