The sensors should all be the same, cause its how the HICAS and ABS operates aswell, using those senors. So im sure the GTR and the GTST would all be the same. Only thing different for yours might be the location of the sensors on the front since you have a diff up there.
  • 1 month later...
My solution to the Active LSD and it's problems was to pull it out and put in a standard diff(shimmed).
If you do this you will have two speed sensors hanging loose, one of these will fit in the front of the standard diff. If you then cut the other one and splice the wires into the sensor loom you are using you will still have ABS and no fault codes.
End of tread.
Ray
OK, the nissan Active-LSD.
basically, these things are a supermodel, they perform fkn fantastic when looked after and groomed, but play up like a smart arse high school girl when u neglect them. FROM MY OWN PERSONAL EXPERIENCE, use only the genuine nissan A-LSD oil and bleed the system every 2nd service. This prevents the dreaded single spinning and tightens up the whole system. Replace the oil every 25,000km. The fault code 75 you have is the tps code, its common. You might also notice a few idle differences, ie jumpy/low/high idle. there are 2 ways to fix this. 1 is to adjust the tps to the correct voltage point, this must be done whils the car is connected to a consult system, which ALL nissan dealerships have, or, replace the tps and adjust the voltage blah blah blah. The 1st is a temp fix, as the tps will be on the way out, UNLESS it had loose bolts and it has slipped. Dont go crying foul on the A-lsd just yet, yes they require more maintenance, but when said maintenance is kept up to it, they are a truly amazing differential.
Cheers, al
  • 1 year later...
hi there i am currently having issues with my a-lsd, i have a power fc and have done the wiring modification for the tps. however i am getting fault codes 62 and 66 and the speedo is very intermittent. any help would be much appreciated as everyone i speak to has no idea. many thanks
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
