Item Summary: 1994 R32 GTR Gunmetal Grey
Condition: Used
Reason for Selling: NEEDS TO GO BY 21st jan!!
Asking Price: 12500
Delivery Methods: PickUp
Contact Info: 0410 290 532
Extra Information: 83xxx km
selling my 1994 r32 gtr, was going to strip it and build a immac donor car for all my running gear out of my other gtr but cant be bothered anymore.
pretty much standard, has an oil cooler kit on it and thats it.
i bought it a year ago and drove it maybe 1000km max, just been sitting around in the shed gathering dust.
rego ran out last month, used to have nsw rego, so all thats needed would be a RWC and get it rego'd i can supply a RWC if needed.
its missing the front lip and the rear upper trims inside the cabin. has no head unit (how i got the car)
sometimes the hicas light flashes so i was informed by a workshop that it would just be better and easier to install a hicas lock bar and remove all the rubbish asscociated with it, which isnt expensive.
overall the car is in pretty good condition, once its detailed next week ill get some pictures, but in essence, its just a standard gunmetal grey R32 GTR.
PM OR SMS 0410 290 532
will consider serious offers.
NEED TO SELL BY 21ST JANUARY!! GOING O/S FOR 3 MONTHS
https://www.sau.com.au/forums/topic/302029-1994-r32-gtr-needs-to-be-sold-asap/
do u guys not read what it says?
- pics wen i get it detailed over weekend
- rego ran out last month so yes it has been complied and regod b4
Hi, Happy New Year Mate,
I'll be in Gold Coast from 11th Jan to 14th. Will call you to discuss further.
sms/pm/call me on 0433 878905
Alex
Mordialloc Melb 3195
Alex
hey, same to u, no worries, let me kno wen ur here
how much would it to have to car sent to sydney?
$500.
some pics.
car sounds and drives really well.
petty faults -
chip on rear wing very small about 5-10mm
drivers window starting to get a little lazy SOMETIMES on the switch
no head unit
drivers seat has had a tear and been stitched up, bolster has worn down a little
small hole/crack in dash, about 5-10mm, maybe from a pervious tacho?
missing the drivers side upper rear trim
CHEAP CAR, DRIVES WELL NEEDS TO GO BY NEXT WEEK!
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
