Item Summary: 1994 R32 GTR Gunmetal Grey
Condition: Used
Reason for Selling: NEEDS TO GO BY 21st jan!!
Asking Price: 12500
Delivery Methods: PickUp
Contact Info: 0410 290 532
Extra Information: 83xxx km
selling my 1994 r32 gtr, was going to strip it and build a immac donor car for all my running gear out of my other gtr but cant be bothered anymore.
pretty much standard, has an oil cooler kit on it and thats it.
i bought it a year ago and drove it maybe 1000km max, just been sitting around in the shed gathering dust.
rego ran out last month, used to have nsw rego, so all thats needed would be a RWC and get it rego'd i can supply a RWC if needed.
its missing the front lip and the rear upper trims inside the cabin. has no head unit (how i got the car)
sometimes the hicas light flashes so i was informed by a workshop that it would just be better and easier to install a hicas lock bar and remove all the rubbish asscociated with it, which isnt expensive.
overall the car is in pretty good condition, once its detailed next week ill get some pictures, but in essence, its just a standard gunmetal grey R32 GTR.
PM OR SMS 0410 290 532
will consider serious offers.
NEED TO SELL BY 21ST JANUARY!! GOING O/S FOR 3 MONTHS
https://www.sau.com.au/forums/topic/302029-1994-r32-gtr-needs-to-be-sold-asap/
do u guys not read what it says?
- pics wen i get it detailed over weekend
- rego ran out last month so yes it has been complied and regod b4
Hi, Happy New Year Mate,
I'll be in Gold Coast from 11th Jan to 14th. Will call you to discuss further.
sms/pm/call me on 0433 878905
Alex
Mordialloc Melb 3195
Alex
hey, same to u, no worries, let me kno wen ur here
how much would it to have to car sent to sydney?
$500.
some pics.
car sounds and drives really well.
petty faults -
chip on rear wing very small about 5-10mm
drivers window starting to get a little lazy SOMETIMES on the switch
no head unit
drivers seat has had a tear and been stitched up, bolster has worn down a little
small hole/crack in dash, about 5-10mm, maybe from a pervious tacho?
missing the drivers side upper rear trim
CHEAP CAR, DRIVES WELL NEEDS TO GO BY NEXT WEEK!
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
