hey guys, we have a couple more things that we need to sell....
600:300:100 core, intercooler in great condition (no damaged, only a couple of very slightly bent fins), came with the car we bought and upgraded to an arc one... $250
R32 GTR standard LSD, has done 70,000k's, in great working condition... $500
R32 GTR gearbox, great condition, no issues at all... also done 70,000k's in its life... $850
R32 GTR standard radiator, good condition, a couple of bent fins, but perfect working, comes with temp sensor and fan shroud. $200
we have plenty more r32 gtr standard stuff too, have a look at our other topics or just pm us...
items located on the far north coast NSW, and we can deliver if you are between lismore and brisbane for an extra $20.
thanks
hey guys, a few more things and some pics
as above for radiator with temp sensor and shroud $200 (removed from a 1992 r32 gtr with 70,000k's-great working order)
radiator with temp sensor-no shroud $150 (removed from a 1994 r32 gtr with around 60,000k's-great working order)
r32 gtr standard cat 2 1/2 inch, reasonable condition, not stuffed or anything... $50
3 inch hi flow cat, good condition... $100
r32 gtr front sway bar, great condition, comes as pictured $80
R32 gtr BOV return pipe, in good condition, apart from a 20cm crack, which can easily be plastic welded $40
standard r32 gtr turbos, some slight play, comes with dumps... $250 pair
r33 gtr v-spec turbos, bought off a member who removed them from his 17,000k car early last year...not used since $350 pair...
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
