  • 3 weeks later...
hey guys, having some issues with my a31, on light throttle at low revs it misses/ skips a beat, but on harder throttle the problem goes away, it only seems to do it when its at normal running temp, any suggestions?
Hey bud,
Generally a miss is caused by a faulty coil pack or spark plug, the best way to check this which you can do yourself pretty easily is to get a alan key and remove the centre cover on top of the rocker cover then get a ten ml spanner and remove one coil pack at a time while the car is running if the idle goes funny the coil pack is fine but if the coil pack you remove is faulty it want make any difference in the idle therefore you have found the source of the problem. Now to fix the problem or try to fix it you should start with changing the spark plugs because they are cheaper you can buy standard spark plugs for less then 5 dollars each but I suggest platinum plugs there better and last longer but more pricy if this doesnt fix it then change the coil pack that you found faulty coil packs are pretty expensive but you can buy them individually, if you get one from the wreckers which isnt a bad idea if want to save money, try test it on the spot.
Good luck champ :D
https://www.sau.com.au/forums/topic/302083-rb20de-miss/#findComment-5041360
