hi!
A friend and I were trying to resolve a issue with missfire at 4.5-5.5k rpm and we tried a ecu diagnostic, coming up with error 34 (knock sensor)
we had already inspected the coil packs for cracks etc (http://www.skylinesaustralia.com/forums/Missfire-Boost4500-5500-t32356.html)
so we had a look at the knock sensor sub harness and it was cut (intentionally by the looks of the cut) so we decided to solder it back together (both copper and outta shielding) and see if we could get that error code fixed.
now when we start the car, it idles normal (800rpm), but as soon as i touch the accelerater it splutters and sounds terrible / undriveable.
read around and is the ecu going into safe mode R&R? i wasn't getting this issue before i repaired the harness. still error 34 after resetting the computer (press brake 1 minute neg off battery)
so we revert to putting the knock sensor back to normal and cut it with plugs left in sensors/loom like before, but still same issue :D (obv not smart but worth a try)
would leaving the negitive off for 48 hours fix the issue? (advised by a friend)
buy genuine harness from nissan with 2 new sensors as my ones are prolly faulty?
are the knock sensors sub harness usually disabled/cut on standard or upgraded r32's for any reason?
my car is r32 gts-t 1989 stock boost 10psi / exhaust / walbro 550 / FMIC
any suggestions would be great thanks :woot:
https://www.sau.com.au/forums/topic/302092-cut-knock-sensor-common/
I can't think of a reason to cut a knock sensor... I would probably try getting new sensors, or if possible, try and diagnose the condition of the current ones (if there is a way).
Leaving your negative off for 48 hours is doing exactly the same thing as dc-ing your battery and applying the brake - it means that there's no charge left in the battery at all, so there's no point doing that if you've already done the brake thing.
thanks for the reply, what has happened is the connector from one of the lines of the sub harness became detached when installing, so we fixed that and did another ecu test.. code 55 All OK !! :)
only thing is the symptoms are still occuring, is it just coinsidence that the knock sensor repair had given me terrible stuttering and when i rev it to 3.5-4rpm im getting vaccum the whole time, no boost?
We actually had changed the fuel pump to a walbro 550 hp pump that morning, so possible a faulty fuel pump??
so i hope that with the bigger fuel pump its pushed a lot of crap into the fuel filter so im going to get it replaced now.
anyway ill have a hunt around the forums since i think i know what the issue is now and get some ideas
one step at a time :D
cheers
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
