hey all
thought i would post up pics of my 33 i have just repainted.
i just turned 3rd year apprentice and this was about my 5th complete repaint
not telling the paint colour :woot: but painted my rims in straight white tinter so there as white as white can be!
i did not complete the panel work got my apprentice panel beater friend to do that for me which took about a week after hours, the paint side took me 2 weeks after hours
the panel beater used minimal bog, just re skimmed the existing bog in the quarters to get rid of waves
i painted all the "insides" and all small bits spoiler mirrors handles etc at home, then drove to work and used the booth to do the outside and bumper bars
i also repainted the wipers and side pillars in black and that completed the respray making the whole thing look new again
i didnt bother doing the engine bay as simply too much effort takaing the engine out to do it, and masking it up would have been a absouloute c**t. plus being black it doesnt look too bad anyway
enjoy :D
https://www.sau.com.au/forums/topic/302130-resprayed-my-33/
Looks good mate! Being in the industry is always a good thing! I'm an apprentice mechanic myself with a few panel beater ans spray painter mates, so you cant beat mates rates!
Just a warning with those wheels... They're a c*nt to clean! I've got the same ones in white, and I want to paint them black :bunny:
Anything else planned for this?
https://www.sau.com.au/forums/topic/302130-resprayed-my-33/#findComment-5013763
thanks guys, yeah i figuered that out about the wheels there were black before and still they looked dirty all the time.
its made 206 atw on 12.5 psi standard turbo im looking at upgrading to a hi-flow so hopefully be making 250+
other than that its got cusco coil overs, racing seat and a few other small mods
this week im having a walbro 550hp fuel pump installed and a hicas lock bar along with the cat removed from exhaust.
theres alot more i want but dont have the $$$ but eventually it will get there.
i want to make it driftable streetable and maybe kinda showable aswel :bunny:
all feedback is apprectated
cheers!!
https://www.sau.com.au/forums/topic/302130-resprayed-my-33/#findComment-5013798
isnt thay light blue that monaros came out in? :thumbsup:
:rolleyes: nah lol, its lighter and that colour is greener but its pretty similar.
the colour was only used in the 70's and its not australian, its italian i think
https://www.sau.com.au/forums/topic/302130-resprayed-my-33/#findComment-5032409
looks a bit like or is the same colour as the calsonic skyline .. also what did they flogg you for the paintwork
its a porche colour. there i said it :(
did the paint work my self mate.
put it this way i saved myself alot in labour time
paint cost me $350
https://www.sau.com.au/forums/topic/302130-resprayed-my-33/#findComment-5051185
thanks for the positive feedback guys!
i wanted to go a colour that i had never seen on a 33 before.. thought i did till like a week after i had painted it i saw another one getting around a very similar colour just a tad darker and he had black rims.
then my mates informed me they have been seeing another look a like around with same color wheels. spewing lol
https://www.sau.com.au/forums/topic/302130-resprayed-my-33/#findComment-5056622
You can always put a few coats of Kandy(ur choice of color) over the top later on if you get too sick being the same Blue as the others.U sprayed it didnt u ,so youll be able to handle that,, P.S whenever u buy or paint something , straight after you start noticing people with the same sh*t,, everytime :down:
https://www.sau.com.au/forums/topic/302130-resprayed-my-33/#findComment-5056938
  • 1 month later...
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
