thanks guys, yeah i figuered that out about the wheels there were black before and still they looked dirty all the time.
its made 206 atw on 12.5 psi standard turbo im looking at upgrading to a hi-flow so hopefully be making 250+
other than that its got cusco coil overs, racing seat and a few other small mods
this week im having a walbro 550hp fuel pump installed and a hicas lock bar along with the cat removed from exhaust.
theres alot more i want but dont have the $$$ but eventually it will get there.
i want to make it driftable streetable and maybe kinda showable aswel :action-smiley-069:
all feedback is apprectated
cheers!!
colour looks nice with white wheels mate ! future plans sound good too :wub:
im guessing you mean 206hp atw not kw ?? seems low, my old 32gtst made 200hp atw with a 3" exhaust and a pod filter
colour looks nice with white wheels mate ! future plans sound good too :action-smiley-069:
No,i'd say he means kw.Or else i think he would have got it fixed before making it look pretty!
Mine made 195kw on stock turbo on a dyno that is said to read low compared to some. Some engines tend to be freaks so you never know :action-smiley-069:
yeh true I suppose, i didnt expect even the measly (in comparison) 200rwhp from my stockish car so i guess the 33 would make a fair bit more
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
