hey guys
looking at buying an older car with some rust
and unsure how to go about fitting the new panel
some resto threads showed me that they tacked them on and then put some putty and stuff ontop to smooth it out
is this the right method?
what setting tig should i use?
im pretty scared with the tig as i have blown some holes into stainless sheets :woot:
the plan shud be, line up clamp,magnet into place, tack, then weld the joins completely sealed, grind/file and sand it smooth .
shudn't really be using putty unless the heat distorted the panel etc
thought so, would tigging be ideal? wat about arc welding?
when welding in panels should you tack it ever say inch, then go back to the beginning and put another tack, over lapping or just under the first lot of tacks and keep repeating till you have welded the hole seam/join.
or is it better to tack it then do one complete weld between each tack one at a time?
cheers
elliot
cheers
elliot
unless you can hammer weld or are good with a shrinking disk you should use the tack method for the panels.
Bear in mind that quickly cooling the area after the weld will cause it to shrink, you just need to be sure that the shrinking effect isnt greater than the expansion caused by the welding.
Further more with regard to the mig, ive got not idea your experience level, but my pick for consumables for a car would be
.8mm er70s-6 wire , co2 sheilding gas and dialing in 40-80 amp. You can go for an argon mix gas to reduce the spatter but its twice the price, per volume.
  • 2 months later...
so you reckon a tig aint any good to weld car pannels? i would have thought it useful no?
Takes to long to generate enough heat to get penetration, than you need to spot it with filler rod... and basically it created to much heat.
your much better off tacking it with a mig, basically tac the whole way around it in a sequence to keep the heat even so the panel doesnt warp.
yea i get you now,the mig is kind of instant,i just bought a miller 275 syncrowave,mainly for alloy ect but i had hoped it would do a bit of boddy work also!looks like ill have to buy more toys,good excuse for the gf!
  • 3 months later...
MIG is definatly the easyest way. tacking all the way round till the whole thing is sealed is the best way. depends on what sorta quality repair you want thought.
most rust repairs or panel joining i do myself, i weld with any oxy welder. purley because you cannot metal finish panels when using mig because is makes the panel to brittle and un- workable. and yes oxy does put out alot of heat but when done propery it is the best method. mig is i lot quicker thou :O
  • 4 weeks later...
:ermm: Hi friend
This is Lilly. I don't have that much knowledge about fabrication. But what you gave that is useful for me.
Thank you.
________________________________________________________________________________
_____
Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups seo pecialist
was going to tell you to use mig like everyone else did!
well howd you go? any pics?
i have no idea about welding car panels. but when we make pharmaceutical tanks, when we weld the seam after weve rolled the tank. we hammer and dolly it just to stress relieve it
http://users.chariot.net.au/~stmezz/rust.htm
this bloke has done a pretty good job, using the tig as well
should probably link you to the finished product as well lol
http://users.chariot.net.au/~stmezz/simons.htm
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
