hey guys
looking at buying an older car with some rust
and unsure how to go about fitting the new panel
some resto threads showed me that they tacked them on and then put some putty and stuff ontop to smooth it out
is this the right method?
what setting tig should i use?
im pretty scared with the tig as i have blown some holes into stainless sheets :woot:
the plan shud be, line up clamp,magnet into place, tack, then weld the joins completely sealed, grind/file and sand it smooth .
shudn't really be using putty unless the heat distorted the panel etc
thought so, would tigging be ideal? wat about arc welding?
when welding in panels should you tack it ever say inch, then go back to the beginning and put another tack, over lapping or just under the first lot of tacks and keep repeating till you have welded the hole seam/join.
or is it better to tack it then do one complete weld between each tack one at a time?
cheers
elliot
cheers
elliot
unless you can hammer weld or are good with a shrinking disk you should use the tack method for the panels.
Bear in mind that quickly cooling the area after the weld will cause it to shrink, you just need to be sure that the shrinking effect isnt greater than the expansion caused by the welding.
Further more with regard to the mig, ive got not idea your experience level, but my pick for consumables for a car would be
.8mm er70s-6 wire , co2 sheilding gas and dialing in 40-80 amp. You can go for an argon mix gas to reduce the spatter but its twice the price, per volume.
  • 2 months later...
so you reckon a tig aint any good to weld car pannels? i would have thought it useful no?
Takes to long to generate enough heat to get penetration, than you need to spot it with filler rod... and basically it created to much heat.
your much better off tacking it with a mig, basically tac the whole way around it in a sequence to keep the heat even so the panel doesnt warp.
yea i get you now,the mig is kind of instant,i just bought a miller 275 syncrowave,mainly for alloy ect but i had hoped it would do a bit of boddy work also!looks like ill have to buy more toys,good excuse for the gf!
  • 3 months later...
MIG is definatly the easyest way. tacking all the way round till the whole thing is sealed is the best way. depends on what sorta quality repair you want thought.
most rust repairs or panel joining i do myself, i weld with any oxy welder. purley because you cannot metal finish panels when using mig because is makes the panel to brittle and un- workable. and yes oxy does put out alot of heat but when done propery it is the best method. mig is i lot quicker thou :O
  • 4 weeks later...
:ermm: Hi friend
This is Lilly. I don't have that much knowledge about fabrication. But what you gave that is useful for me.
Thank you.
________________________________________________________________________________
_____
Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups seo pecialist
was going to tell you to use mig like everyone else did!
well howd you go? any pics?
i have no idea about welding car panels. but when we make pharmaceutical tanks, when we weld the seam after weve rolled the tank. we hammer and dolly it just to stress relieve it
http://users.chariot.net.au/~stmezz/rust.htm
this bloke has done a pretty good job, using the tig as well
should probably link you to the finished product as well lol
http://users.chariot.net.au/~stmezz/simons.htm
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
