  • Replies 164
Posted Images
SO i bought my first ever DSLR. These are my favourites from my first 500 photos ive taken in the first week ive owned the camera. Im super super noob so please add any constructive criticism but please explain with lotsa detail :( None of these have any digital touch ups or anything, just as shot.
So you're the one that bought Ando's car.. ? http://www.redbubble.com/people/samboaus/a...8659-10-the-s13
Negative. i still have my white 33 thats getting work done. My older brother Leif bought Ando's car and is selling his current s13.
One I took of my cat a few years ago :ph34r: I don't really do the special camera thing, the most I had was an old film Pentax SLR.. just on canon Ixus' now.
You can't see it (der) but I photoshopped some blue plastic out of the background.
The second one is just a collection of sunsets from the place I grew up.
Couple I did tonight just messing about.
Bit messy, need practice and a darker location *shakes fist at streetlight*
http://photos.jay019.com/random/
This may pose to have no actual relevance to the thread, or anyone here..but how do you actually do this?
I don't actually have a DSLR, or any photographic experience (apart from with a p&s) but this is awesome stuff!
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
