You said that you wanted to build a 4 door GT-R. Genuine, factory built, GT-R sedans are almost impossible to find.
My point is that doing it yourself by getting a 4 door chassis and transplanting the engine/driveline from a GT-R coupe into it is going to be a massive job with lots of custom work from whichever workshop you eventually get to help you with it. The end result is more prone to failure than a 4 door car that left the factory with an AWD drivetrain, and OEM levels of engineering and testing behind it.
If you're talking about just dropping an RB26DETT into a sedan chassis then it should be relatively simple, and reliability will come down more to how you treat the car than anything else. But, to be quite blunt, the GT-R is defined more by its advanced drivetrain than its engine so that car wouldn't be a "4 door GT-R" any more than some ricer who sticks badges on their GTS-t.
If you intend on having the GT-R's ATTESSA (which is different to the GTS4's ATTESSA) fitted as well as the engine into a sedan, which would make it more worthy of the title, then you're going to need deep pockets and people who really know what they're doing. Even then, I'd still be worried that things had to be kludged to fit/work, which means it's more likely to break than a car that was designed to be that way in the first place.
Check out these threads.
http://www.skylinesaustralia.com/forums/98...Gt-t297401.html
http://www.skylinesaustralia.com/forums/R3...ld-t280439.html
My opinion:
If you are going the R34 N/A route - Keep the 4 door as "daily spec" - With minimal mods. High flow panel filter, extractors and a decent sounding stereo (not the full DOOF DOOF stuff - adds so much weight and takes boot space) and some nice alloys. This will also enable you to get parts from the nissan dealerships.
R34 non-turbo are not quick cars (on par with your typical n/a aussie 6s), however they do keep pace with the "majority" of cars out there - so they are not underpowered by any means. I'd put them as VERY average. Only real advantage of the n/a R34 is the better handling and the good looks (majority of people out there have no clue between the bread and butter GT/GT-T to the GT-R).
When you save up enough you could probably end up having 2 cars :P R34 4 door as a daily and a GT-R for the weekend/having fun...
I just picked up a R32 sedan gtst with Rb26dett conversion
plenty of mods done to it, upgraded brakes, tein suspension, 750cc injectors, ecu, gtr fuel pump, etc
they are around, need to be quick tho when they pop up
about to strip it into a track biatch
unless you want it for 10k ;)
buy a POS first car cheap as chips
save as much money as you can in the mean time
when off p's buy an ER34 GTT and youll be fine
ER34 GTT to GTR conversion is stupid, pointless, not worth the $ and a waste of time
the money youll spend all up - you could just buy a GTR R34 for the price they are now
the converted ER34 GTT to GTR will be worth nothing in comparison to what you spend
